    How to get 1 or 2 meter NFC Communication ??
    • mubassir mk
      mubassir mk last edited by
      I have wristband(like smart watch) and another stationary device ,when the wristband reaches within 1 meter of the stationary device,stationary device want to show some indication for that i can use NFC communication? if yes how to get 1 meter NFC communication??
        @mubassir-mk Why do you wanna use NFC. Does your wrist band have BLE? If yes, you can easily make this application with BLE.
        Please watch this video
        mubassir mk 1 Reply Last reply Reply Quote 0
          Hi @mubassir-mk, The NFC tag and reader can work only in Shorter working distance up to 10cm only. but Instead of that like @kowshik1729 suggested, you can try the BLE beacons since the BLE is active you need to power the device, but you can buy readymade beacons which can work with iBeacon or Eddystone protocols and it can work years using single coin cell battery.
          Do you have any other particular reason to use the NFC?
          • mubassir mk
            mubassir mk @kowshik1729 last edited by
            @kowshik1729 Thank you....
            Very help full your replay ...
              @mubassir-mk Glad that it helped.
              • Convert MBOX to PST for free using built-in tools and limited free utilities. The most reliable no-cost method is Thunderbird + Outlook via IMAP: add your MBOX into Thunderbird, connect the same IMAP account in both Thunderbird and Outlook, copy mails from MBOX folders to the IMAP account in Thunderbird, then let Outlook sync and export to PST via File > Open & Export > Export to a file > Outlook Data File (.pst).
                If you prefer direct conversion, some tools offer constrained free tiers: Outlook Freeware “Convert MBOX to PST” add-in works locally with Outlook installed (free for personal use, check limits). vMail online converter is free up to 100 MB per MBOX; larger files require paid desktop software. Microsoft Store apps and trialware often allow 25–30 items per folder or a small batch to PST at no cost—use for small jobs or to test before upgrading.
                Buy Now- vSoftware
                There are many scenarios when an users need to convert MBOX files to PST format. This task can be easily done by using EmailsGuru MBOX to PST Converter. It is completely reliable and easy to use tool to perform smooth and error-free MBOX to PST Conversion process. It is best way to export MBOX files to Outlook PST format, which enable users to access or import all MBOX mailbox data to Outlook 2021, 2019, 2016 and all below versions. It easily convert MBOX files of all major email clients like Mozilla Thunderbird, Netscape, Opera Mail, Yahoo Mail, Apple Mail and many others. Users can smoothly run this tool on any Windows supported platform and use a free trial version to convert 25 MBOX files to PST.
