    SMD Connectors for Inter board connections
    1223
      @salmanfaris I'm looking for something very small and with less pin count(probably 4). Something like as shown below.
      but I need a connecting wire that correctly fits these connectors. So, Can you suggest me a receptacle and wire pair?
        salmanfaris @kowshik1729 last edited by salmanfaris
        @kowshik1729 But you need to stack the PCB on top another right?
        If you need these type connector you can check Seeed Grove connector with grove cable or Sparkfun Qwiic with Qwiic cable
        Seeed Grove
        Sparkfun Qwiic
          @salmanfaris No, I will not stack the PCBs on top of each other. I'll be daisy-chaining them, I guess the second picture which you kept is good but are those connectors SMD?
          I need strictly SMD.
            @kowshik1729 If you need to stack the PCB, then check the first comment I made all of them are SMD
            @kowshik1729 said in SMD Connectors for Inter board connections:
            In the second comment you shown JST connector and that's a horizontal connector, you can't stack PCB vertically with that.
              @salmanfaris Great. Can I know the manufacturer part number please? It would be easy for me to take my design to production easily.😊
                @kowshik1729 Sure, I already mentioned that in the post itself, please check.
                  @kowshik1729 The Sparkfun Qwiic Connector Libray can be found in the Sparkfun Eagle library under SparkFun-Connectors.lbr->Qwiic Connector.
