    [Solved] Help needed to setup burpsuits!
    1472
    • Nandu
      Nandu @husinul last edited by
      @husinul in my browser http://burp isn't working that's why i have exported certificate from the burpuite software itself.There is an option for exporting certificate in der format.
      H 1 Reply Last reply Reply Quote 0
      • H
        husinul @Nandu last edited by
        @Nandu yes i got this, in that way also you can import the certificate.
        Nandu 1 Reply Last reply Reply Quote 0
        • Nandu
          @husinul but after adding also web browser isn't responding.
          one doubt:In your browser is http://burp working.
          • H
            Did you remove old certificate, mine is working.
            • Nandu
              @husinul yes.
              • Nandu
                Problem no longer exists.Thankyou
