    [Solved] Why STM Microcontroller are Popular?
    mcu
    • 0
      0pencircuit last edited by salmanfaris
      Why STM microcontrollers are getting more popular these days? the best material to start with STM?
        @0pencircuit The answer to your question brings in many parameters to be discussed. No product can become a hit in the market just like that. It involves lot of technical support and some of the best marketing strategies for a product to become popular. But, as we discuss more about technical stuff in here I would give some brief specifications of STM32 why it became a hit in market for learning embedded systems.
        1. Board is designed in such a way that it can be interfaced very easily with Arduino IDE and through it's HAL's like STM32 Cube.
        2. Excellent community support for STM32.
        3. If you observe the size of STM32 chip it's really pretty small which enables it's usage for designing really small and qualitative commercial grade products.
        It is super easy to learn and doesn't involves hard macro forms( to be simple "Syntax"). The best way to learn this board is to download this course. As far as I researched this course has given me good path to learn STM32. They teach you all the concepts very carefully. Download the course from this Torrent Link
        0 1 Reply Last reply Reply Quote 1
          Hi @0pencircuit ,
          Actually the STM (STMicroelectronics) is the company name who makes the STM32 is a family of 32-bit Microcontroller based on ARM architecture and it comes in a wide variety of models and the selection depends on your applications.
          Source : st.com
          • 0
            0pencircuit @kowshik1729 last edited by
            @kowshik1729 thanks bro
