    Water depth sensor
    1306
      Geethesh last edited by Geethesh
      I want to make a water depth sensor .
      I have seen some YouTube videos of water proof ultrasonic sensor ,but it's will not work under water.
      Please any one tell me which sensor should I use.
      I want to sense it he depth of water.
      From surface to the bottom .
      The sensor should be on the surface of water
        @Geethesh Glad that you are active with makergram. To help with your query please let me clarify whether you want to know the level of the water surface or know how much depth a certain water body is at??
        Geethesh 2 Replies Last reply Reply Quote 1
          @kowshik1729 I want to sense the depth of water .
          From surface to bottom
            @kowshik1729 I edited my question.
              salmanfaris @Geethesh last edited by salmanfaris
              Hi @Geethesh ,
              I got a few sensors to measure the depth of water, some of them are listed .
              • MS5540C , example link
              • Bar30 High-Resolution 300m Depth/Pressure Sensor
              • Miniature Barometer Module * OTT ecoLog 1000 Water Level Logger
                @Geethesh Try using Sharp IR sensor.....it's more effective than normal IR and can measure distances accurately using ir Rays. Try using it.
                  Geethesh @salmanfaris last edited by
                  @salmanfaris thanks for the details
