    Vehicle data retrieving
    Raspberry Pi
    iot raspberrypi nodemcu
    922
    • Abhay
      Abhay last edited by
      Which will serve better for the purpose of data retrieving from vehicles, NodeMCU or Rasberry pi
      It is for the purpose of securing information via blockchain. (we want to store the retrived data using blockchain)
        @Abhay can you please let us know what kind of vehicle data would you require?? Because there are very easy ways I can suggest if what parameters do you want to obtain from vehicles?
        And also let us know whether you are planning to require the data for cars???
        Abhay 1 Reply Last reply Reply Quote 1
          Hi @Abhay ,
          I don't know what exactly your application is or what you are going to do with the data is ? if you want to read vehicle data you can use OBD-II CAN-BUS development kit. also for the esp vs raspberry pi decision is also depends upon what you are doing with the data.
          Abhay 1 Reply Last reply Reply Quote 2
          • Abhay
            Abhay @kowshik1729 last edited by
            @kowshik1729 accelerometer reading, gps location, airbag activation etc. Are the main reading were are looking at present. We are planing to collect it from car as a live demo and store it using blockchain.
            • Abhay
              Abhay @salmanfaris last edited by
              @salmanfaris OBD devices are in every new cars right, I don't know if I am right but I think we need seperate android app to collect data using obd and i think it don't retrive accelerometer reading i guess.
                salmanfaris @Abhay last edited by salmanfaris
                Hi @Abhay ,
                Yes, OBD interfaces are now available in most the cars these days , you can get the vehicle sensor data using the OBD interface and you can process it using any controller like esp8266 or something.
                Car => Data => OBD => Micorcontroller
                • Abhay
                  @salmanfaris don't we need seperate android apps for collecting those data.?
                    @Abhay As you mentioned, I strongly feel that, the infotainment systems inside the cars these days aren't serving data like GPS location and all. I have used the OBD(On-Board Diagnostics) module in order to acquire data like Fuel tank levels, acceleration of the car, Brake levels, Battery levels, etc., In order to acquire the data like GPS you can install your own GPS module like UBLOX GPS sensor which can be easily interfaced over UART of any MCU's like ESP8266, ESP32, Arduino etc., and pertaining to your last question in the thread I would say "NO" you don't need any separate android apps to obtain data from OBD devices(if they are Bluetooth enabled). Because OBD's like ELM327 is Bluetooth enabled and hence you can use a simple Bluetooth terminal app to connect and get the data.
                    • Abhay
                      Hi @kowshik1729
                      Thank you for the insight. Will definitely post further queries here as we progress on the project. Hope you could suggest answers like these again. Thank you
                        @Abhay Glad that it helped you. Yes, I can suggest you with the queries as far as I know. All the best..!!✌
                        • Hi @borncurious , For the industrial purpose you can go with Raspberry Pi compute modules, Take a look at the latest version CM4 - https://www.raspberrypi.com/products/compute-module-4/ , Which is designed for industrial usage and incorporates a quad-core ARM Cortex-A72 processor, dual video output, and a wide selection of other interfaces. Available in 32 variants, with a range of RAM and eMMC Flash options, and with or without wireless connectivity.
                          Other options are, boards like RockPi and Orange Pi boards which are similar to Raspberry similar model and specs but the price is a bit lower than the raspberry pi. Make sure to check the Interface and driver support that you need to incorporate into your project since these boards are not documented and maintained like the official raspberry pi as far as I know.
                          also, you can check Toradex System on Module.
                        • B
                          Is raspi generally used in commercial product/end product.if not can u guys suggest raspi alternatives for end products.
                        • https://www.youtube.com/watch?v=1EIFfln3Kxs&t=1s
                          The classic compact camera for Raspberry Pi with a 12MP sensor and autofocus
                          Available from $25 with your choice of standard and wide lenses, with or without an infrared filter
                          More details: https://www.raspberrypi.com/products/camera-module-3/
                          https://youtu.be/XwYRSlqCN3A
                          Resource:
                          Documentation: https://www.raspberrypi.com/documentation/accessories/camera.html
                          Camera Software: https://www.raspberrypi.com/documentation/computers/camera_software.html
                        • Hey @rafitc99 ,
                          Did your issue resolve? Curious to know 😊
