    Altium Hierarchy->harness in Schematic
    schematic altium
      Geethesh last edited by
      Hi team,
      Any one have experience in Altium schematic designing.
      I am facing some issue in Hierarchy->harness in Schematic.
      The offpage number for harness is not showing, and while generation the smart PDF if we click the harness port /green box the page want to go there automatically, but that also not working.
