    Edge Impulse Inference to IoT Dashboard
    edge impulse
    2650
      dipu_varghese @salmanfaris last edited by
      Thank you for your response! @salmanfaris 🙂
      It makes sense that filtering out the specific data points that are needed and sending them to the cloud would be the way to go.
      If it's not too much trouble, could you please provide me with an example of how to filter out and send only the necessary inferencing data to the cloud?
      Thank you again for your help!
      Best,
      Dipu
        salmanfaris @dipu_varghese last edited by
        @dipu_varghese Sure, I'll try to make an example in one coming day and share.
        D 2 Replies Last reply Reply Quote 0
          @salmanfaris I really appreciate your help and look forward to seeing the example.
          Best,
          Dipu
          D 1 Reply Last reply Reply Quote 0
            dipu_varghese @dipu_varghese last edited by
            @salmanfaris Hope you're doing well, did you get sometime to work on this?
            Best,
            Dipu
              @salmanfaris any updates?
              Best,
              Dipu
                salmanfaris @dipu_varghese last edited by salmanfaris
                Hi @dipu_varghese ,
                Here is the sample input from the binary edge impulse inference,
                Predictions (DSP: 16 ms., Classification: 1 ms., Anomaly: 2 ms.):
                idle: 0.91016
                snake: 0.08203
                updown: 0.00391
                wave: 0.00391
                anomaly score: -0.067”
                And from here for example we can try to get the updown values only by attaching the device to another controller and read the Serial string directly.
                  // Start serial communication at 9600 baud
                  // Wait until there is data available on the serial port
                  while (!Serial.available()) {
                    // Do nothing
                  // Read the input string from the serial port
                  String inputString = Serial.readStringUntil('\n');
                  // Find the position of the "updown" value in the input string
                  int updownPos = inputString.indexOf("updown:");
                  // If the "updown" value was found in the input string
                  if (updownPos >= 0) {
                    // Extract the "updown" value from the input string
                    String updownString = inputString.substring(updownPos + 8, inputString.indexOf('\n', updownPos));
                // Convert the "updown" value to a float
                    float updownValue = updownString.toFloat();
                 // Output the "updown" value
                    Serial.println(updownValue);
                The sketch should then output the "updown" value, which is 0.08203.
                Hope this will be helpful, let me know if you need more clarification.
                  @salmanfaris thank you so much man, I'll try this and update you shortly. Thank you once again.
                  Best,
                  Dipu
                    @dipu_varghese Hi, How does it go? Would like to know about the updates 🙂 or anything I can do to help you.
