    Help needed: Arduino Wireless Notice Board project
    7036
      SAFVAN last edited by salmanfaris
      I'm making a Wireless Notice Board for my project purpose. Simply the expected working is... "Sending a message from our mobile handset to sim which inserted to SIM900A GSM Module Arduino read the message and display through P10 LED display."
      Recieving SMS system and P10 LED display are working separately. These programs are combined. SMS are received (we can see in serialmonitor). But it cannot display. Displaying what is written in the program only
      #include <SoftwareSerial.h>
      #include <SPI.h>
      #include <DMD.h>
      #include <TimerOne.h>
      #include "SystemFont5x7.h"
      #include "Arial_black_16.h"
      #define ROW 1
      #define COLUMN 1
      #define FONT Arial_Black_16
      DMD led_module(ROW, COLUMN);
      String st;
      const char *msg;
      unsigned int LengMsg;
      SoftwareSerial mySerial(3, 2);
      void scan_module(){
        led_module.scanDisplayBySPI();
        Timer1.initialize(2000);
        Timer1.attachInterrupt(scan_module);
        led_module.clearScreen( true );
        Serial.begin(4800);
        mySerial.begin(4800);
        Serial.println("Starting...");
        delay(1000);
        mySerial.println("AT");
        pollSms();
        mySerial.println("AT+CMGF=1");
        pollSms();
        mySerial.println("AT+CNMI=1,2,0,0,0");
        pollSms();
      void loop(){
        pollSms();
        delay(500);
        //Start print in led matrix
        led_module.selectFont(FONT);
        led_module.drawMarquee(msg,LengMsg, (32 * ROW), 0);
        long start = millis();
        long timming = start;
        boolean flag = false;
        while (!flag){
          if((timming + 20) < millis()){
              flag = led_module.stepMarquee(-1, 0);
              timming = millis();
      void pollSms(){
        delay(500);
        while (Serial.available()) {
          mySerial.write(Serial.read());
          String st = String(Serial.read());
          Serial.println(st);
        while(mySerial.available()) {
          Serial.write(mySerial.read());
          st = String(Serial.readString());
          Serial.println(st);
          LengMsg = st.length();
          st.toCharArray(msg,LengMsg);
        delay(500);
      S 1 Reply Last reply Reply Quote 1
        @SAFVAN Thanks for posting the query. I would like to know what is the exact part number or any picture of the Display you're using and I wanna know what connections have you made.
        Please post these details such that it becomes easy for us to review.!!
          @SAFVAN are you getting any error or something ?
            rafitc99 @salmanfaris last edited by
            @salmanfaris no any error, issue is in that LED metrix library print function parameters are *const char. So need to convert SMS boast string to const char *Variable.
              SAFVAN @SAFVAN last edited by
              @kowshik1729 display is 16×32 P10 LED display.
              RX and TX connected pin 3&2.
              P10 connected as https://circuitdigest.com/microcontroller-projects/digital-notice-board-using-p10-led-matrix-display-and-arduino
                salmanfaris @rafitc99 last edited by salmanfaris
                Hi @rafitc99, You can convert the string to char array using toCharArray() it will Copies the String’s characters to the supplied buffer.
                • Syntax
                myString.toCharArray(buf, len)
                • Parameters
                  myString: a variable of type String.
                  buf: the buffer to copy the characters into. Allowed data types: array of char.
                  len: the size of the buffer. Allowed data types: unsigned int.
                more : https://www.arduino.cc/reference/en/language/variables/data-types/string/functions/tochararray/ , https://www.arduino.cc/en/Tutorial/BuiltInExamples#strings
                also @SAFVAN is using const char* to hold message array You cannot change the contents of the location(s) this pointer points to.
                  @salmanfaris Rewrite all code and uploaded. But SMS is not displaying correctly in LED Board, .. I'm attaching code and display output. take a look ,
                  #include <SPI.h>
                  #include <DMD.h>
                  #define ROW 1
                  #define COLUMN 1
                  String st;
                  const char *msg;
                  void scan_module(){
                    Serial.begin(4800);
                    delay(1000);
                    pollSms();
                    pollSms();
                    pollSms();
                  void loop(){
                    pollSms();
                    delay(500);
                    while (!flag){
                          timming = millis();
                  void pollSms(){
                    delay(500);
                      //String st = String(Serial.read());
                      //Serial.println(st);
                      st = String(mySerial.readString());
                      Serial.println(st);
                    delay(500);
                  output video : video link
                  A 1 Reply Last reply Reply Quote 0
                    Can you print the SMS on the serial monitor too? so we can conclude the problem
                      @salmanfaris in serial monitor getting normal text. No problem in there.
                        @rafitc99 Okay, it might be sending char from SMS buffer to LED panel. let me check, I'll get back to you.
