    Error of compiling for the AI thinker
    • P
      Parves DOMINO last edited by
      I am working on an object detection since 2 weeks. I have started the project by a testing object using edge impulse to create the library based on this object but when i compile the code i have an error
      That's the code
      #include <Parvesdomino-project-IPT_inferencing.h>
      #include "edge-impulse-sdk/dsp/image/image.hpp"
      #include "esp_camera.h"
      // Select camera model - find more camera models in camera_pins.h file here
      // https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
      //#define CAMERA_MODEL_ESP_EYE // Has PSRAM
      #define CAMERA_MODEL_AI_THINKER // Has PSRAM
      #if defined(CAMERA_MODEL_ESP_EYE)
      #define PWDN_GPIO_NUM    -1
      #define RESET_GPIO_NUM   -1
      #define XCLK_GPIO_NUM    4
      #define SIOD_GPIO_NUM    18
      #define SIOC_GPIO_NUM    23
      #define Y9_GPIO_NUM      36
      #define Y8_GPIO_NUM      37
      #define Y7_GPIO_NUM      38
      #define Y6_GPIO_NUM      39
      #define Y5_GPIO_NUM      35
      #define Y4_GPIO_NUM      14
      #define Y3_GPIO_NUM      13
      #define Y2_GPIO_NUM      34
      #define VSYNC_GPIO_NUM   5
      #define HREF_GPIO_NUM    27
      #define PCLK_GPIO_NUM    25
      #elif defined(CAMERA_MODEL_AI_THINKER)
      #define PWDN_GPIO_NUM     32
      #define XCLK_GPIO_NUM      0
      #define SIOD_GPIO_NUM     26
      #define SIOC_GPIO_NUM     27
      #define Y9_GPIO_NUM       35
      #define Y8_GPIO_NUM       34
      #define Y7_GPIO_NUM       39
      #define Y6_GPIO_NUM       36
      #define Y5_GPIO_NUM       21
      #define Y4_GPIO_NUM       19
      #define Y3_GPIO_NUM       18
      #define Y2_GPIO_NUM        5
      #define VSYNC_GPIO_NUM    25
      #define HREF_GPIO_NUM     23
      #define PCLK_GPIO_NUM     22
      #else
      #error "Camera model not selected"
      #endif
      /* Constant defines -------------------------------------------------------- */
      #define EI_CAMERA_RAW_FRAME_BUFFER_COLS           320
      #define EI_CAMERA_RAW_FRAME_BUFFER_ROWS           240
      #define EI_CAMERA_FRAME_BYTE_SIZE                 3
      /* Private variables ------------------------------------------------------- */
      static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
      static bool is_initialised = false;
      uint8_t *snapshot_buf; //points to the output of the capture
      static camera_config_t camera_config = {
          .pin_pwdn = PWDN_GPIO_NUM,
          .pin_reset = RESET_GPIO_NUM,
          .pin_xclk = XCLK_GPIO_NUM,
          .pin_sscb_sda = SIOD_GPIO_NUM,
          .pin_sscb_scl = SIOC_GPIO_NUM,
          .pin_d7 = Y9_GPIO_NUM,
          .pin_d6 = Y8_GPIO_NUM,
          .pin_d5 = Y7_GPIO_NUM,
          .pin_d4 = Y6_GPIO_NUM,
          .pin_d3 = Y5_GPIO_NUM,
          .pin_d2 = Y4_GPIO_NUM,
          .pin_d1 = Y3_GPIO_NUM,
          .pin_d0 = Y2_GPIO_NUM,
          .pin_vsync = VSYNC_GPIO_NUM,
          .pin_href = HREF_GPIO_NUM,
          .pin_pclk = PCLK_GPIO_NUM,
          //XCLK 20MHz or 10MHz for OV2640 double FPS (Experimental)
          .xclk_freq_hz = 20000000,
          .ledc_timer = LEDC_TIMER_0,
          .ledc_channel = LEDC_CHANNEL_0,
          .pixel_format = PIXFORMAT_JPEG, //YUV422,GRAYSCALE,RGB565,JPEG
          .frame_size = FRAMESIZE_QVGA,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
          .jpeg_quality = 12, //0-63 lower number means higher quality
          .fb_count = 1,       //if more than one, i2s runs in continuous mode. Use only with JPEG
          .fb_location = CAMERA_FB_IN_PSRAM,
          .grab_mode = CAMERA_GRAB_WHEN_EMPTY,
      /* Function definitions ------------------------------------------------------- */
      bool ei_camera_init(void);
      void ei_camera_deinit(void);
      bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) ;
      * @brief      Arduino setup function
      void setup()
          // put your setup code here, to run once:
          Serial.begin(115200);
          //comment out the below line to start inference immediately after upload
          while (!Serial);
          Serial.println("Edge Impulse Inferencing Demo");
          if (ei_camera_init() == false) {
              ei_printf("Failed to initialize Camera!\r\n");
          else {
              ei_printf("Camera initialized\r\n");
          ei_printf("\nStarting continious inference in 2 seconds...\n");
          ei_sleep(2000);
      * @brief      Get data and run inferencing
      * @param[in]  debug  Get debug info if true
      void loop()
          // instead of wait_ms, we'll wait on the signal, this allows threads to cancel us...
          if (ei_sleep(5) != EI_IMPULSE_OK) {
              return;
          snapshot_buf = (uint8_t*)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
          // check if allocation was successful
          if(snapshot_buf == nullptr) {
              ei_printf("ERR: Failed to allocate snapshot buffer!\n");
              return;
          ei::signal_t signal;
          signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT;
          signal.get_data = &ei_camera_get_data;
          if (ei_camera_capture((size_t)EI_CLASSIFIER_INPUT_WIDTH, (size_t)EI_CLASSIFIER_INPUT_HEIGHT, snapshot_buf) == false) {
              ei_printf("Failed to capture image\r\n");
              free(snapshot_buf);
              return;
          // Run the classifier
          EI_IMPULSE_ERROR err = run_classifier(&signal, &result, debug_nn);
          if (err != EI_IMPULSE_OK) {
              ei_printf("ERR: Failed to run classifier (%d)\n", err);
              return;
          // print the predictions
          ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
                      result.timing.dsp, result.timing.classification, result.timing.anomaly);
      #if EI_CLASSIFIER_OBJECT_DETECTION == 1
          ei_printf("Object detection bounding boxes:\r\n");
          for (uint32_t i = 0; i < result.bounding_boxes_count; i++) {
              ei_impulse_result_bounding_box_t bb = result.bounding_boxes[i];
              if (bb.value == 0) {
                  continue;
              ei_printf("  %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
                      bb.label,
                      bb.value,
                      bb.x,
                      bb.y,
                      bb.width,
                      bb.height);
          // Print the prediction results (classification)
      #else
          ei_printf("Predictions:\r\n");
          for (uint16_t i = 0; i < EI_CLASSIFIER_LABEL_COUNT; i++) {
              ei_printf("  %s: ", ei_classifier_inferencing_categories[i]);
              ei_printf("%.5f\r\n", result.classification[i].value);
      #endif
          // Print anomaly result (if it exists)
      #if EI_CLASSIFIER_HAS_ANOMALY
          ei_printf("Anomaly prediction: %.3f\r\n", result.anomaly);
      #endif
      #if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
          ei_printf("Visual anomalies:\r\n");
          for (uint32_t i = 0; i < result.visual_ad_count; i++) {
              ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
                  continue;
                      bb.label,
                      bb.value,
                      bb.x,
                      bb.y,
                      bb.width,
                      bb.height);
      #endif
          free(snapshot_buf);
       * @brief   Setup image sensor & start streaming
       * @retval  false if initialisation failed
      bool ei_camera_init(void) {
          if (is_initialised) return true;
        pinMode(13, INPUT_PULLUP);
        pinMode(14, INPUT_PULLUP);
      #endif
          //initialize the camera
          esp_err_t err = esp_camera_init(&camera_config);
          if (err != ESP_OK) {
            Serial.printf("Camera init failed with error 0x%x\n", err);
            return false;
         // sensor_t * s = esp_camera_sensor_get();
          // initial sensors are flipped vertically and colors are a bit saturated
          //if (s->id.PID == OV3660_PID) {
           // s->set_vflip(s, 1); // flip it back
           // s->set_brightness(s, 1); // up the brightness just a bit
          //  s->set_saturation(s, 0); // lower the saturation
      #if defined(CAMERA_MODEL_M5STACK_WIDE)
          s->set_vflip(s, 1);
          s->set_hmirror(s, 1);
      #elif defined(CAMERA_MODEL_ESP_EYE)
          s->set_vflip(s, 1);
          s->set_awb_gain(s, 1);
      #endif
          is_initialised = true;
          return true;
       * @brief      Stop streaming of sensor data
      void ei_camera_deinit(void) {
          //deinitialize the camera
          esp_err_t err = esp_camera_deinit();
          if (err != ESP_OK)
              ei_printf("Camera deinit failed\n");
              return;
          return;
       * @brief      Capture, rescale and crop image
       * @param[in]  img_width     width of output image
       * @param[in]  img_height    height of output image
       * @param[in]  out_buf       pointer to store output image, NULL may be used
       *                           if ei_camera_frame_buffer is to be used for capture and resize/cropping.
       * @retval     false if not initialised, image captured, rescaled or cropped failed
      bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) {
          bool do_resize = false;
          if (!is_initialised) {
              ei_printf("ERR: Camera is not initialized\r\n");
              return false;
          camera_fb_t *fb = esp_camera_fb_get();
          if (!fb) {
              ei_printf("Camera capture failed\n");
              return false;
         bool converted = fmt2rgb888(fb->buf, fb->len, PIXFORMAT_JPEG, snapshot_buf);
         esp_camera_fb_return(fb);
         if(!converted){
             ei_printf("Conversion failed\n");
             return false;
          if ((img_width != EI_CAMERA_RAW_FRAME_BUFFER_COLS)
              || (img_height != EI_CAMERA_RAW_FRAME_BUFFER_ROWS)) {
              do_resize = true;
          if (do_resize) {
              ei::image::processing::crop_and_interpolate_rgb888(
              out_buf,
              EI_CAMERA_RAW_FRAME_BUFFER_COLS,
              EI_CAMERA_RAW_FRAME_BUFFER_ROWS,
              out_buf,
              img_width,
              img_height);
          return true;
      static int ei_camera_get_data(size_t offset, size_t length, float *out_ptr)
          // we already have a RGB888 buffer, so recalculate offset into pixel index
          size_t pixel_ix = offset * 3;
          size_t pixels_left = length;
          size_t out_ptr_ix = 0;
          while (pixels_left != 0) {
              // Swap BGR to RGB here
              // due to https://github.com/espressif/esp32-camera/issues/379
              out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix + 2] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix];
              // go to the next pixel
              out_ptr_ix++;
              pixel_ix+=3;
              pixels_left--;
          // and done!
          return 0;
      #if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_CAMERA
      #error "Invalid model for current sensor"
      #endif
      And here is the error:
      C:\Users\HP\AppData\Local\Temp\.arduinoIDE-unsaved202486-9240-1p71wzh.ggfb\esp32_camera\esp32_camera.ino:382:2: error: #error "Invalid model for current sensor"
        382 | #error "Invalid model for current sensor"
      Compilation error: #error "Invalid model for current sensor"
      Please help me to solve this.
        salmanfaris @Parves DOMINO last edited by
        @Parves-DOMINO Are you still facing the issue?
