    Error of compiling for the AI thinker esp-
    • P
      Parves DOMINO last edited by
      I am working on an object detection since 2 weeks. I have started the project by a testing object using edge impulse to create the library based on this object but when i compile the code i have an error
      That's the code:
      #include <Parvesdomino-project-IPT_inferencing.h>
      #include "edge-impulse-sdk/dsp/image/image.hpp"
      #include "esp_camera.h"
      // Select camera model - find more camera models in camera_pins.h file here
      // https://github.com/espressif/arduino-esp32/blob/master/libraries/ESP32/examples/Camera/CameraWebServer/camera_pins.h
      //#define CAMERA_MODEL_ESP_EYE // Has PSRAM
      #define CAMERA_MODEL_AI_THINKER // Has PSRAM
      #if defined(CAMERA_MODEL_ESP_EYE)
      #define PWDN_GPIO_NUM -1
      #define RESET_GPIO_NUM -1
      #define XCLK_GPIO_NUM 4
      #define SIOD_GPIO_NUM 18
      #define SIOC_GPIO_NUM 23
      #define Y9_GPIO_NUM 36
      #define Y8_GPIO_NUM 37
      #define Y7_GPIO_NUM 38
      #define Y6_GPIO_NUM 39
      #define Y5_GPIO_NUM 35
      #define Y4_GPIO_NUM 14
      #define Y3_GPIO_NUM 13
      #define Y2_GPIO_NUM 34
      #define VSYNC_GPIO_NUM 5
      #define HREF_GPIO_NUM 27
      #define PCLK_GPIO_NUM 25
      #elif defined(CAMERA_MODEL_AI_THINKER)
      #define PWDN_GPIO_NUM 32
      #define XCLK_GPIO_NUM 0
      #define SIOD_GPIO_NUM 26
      #define SIOC_GPIO_NUM 27
      #define Y9_GPIO_NUM 35
      #define Y8_GPIO_NUM 34
      #define Y7_GPIO_NUM 39
      #define Y6_GPIO_NUM 36
      #define Y5_GPIO_NUM 21
      #define Y4_GPIO_NUM 19
      #define Y3_GPIO_NUM 18
      #define Y2_GPIO_NUM 5
      #define VSYNC_GPIO_NUM 25
      #define HREF_GPIO_NUM 23
      #define PCLK_GPIO_NUM 22
      #else
      #error "Camera model not selected"
      #endif
      /* Constant defines -------------------------------------------------------- */
      #define EI_CAMERA_RAW_FRAME_BUFFER_COLS 320
      #define EI_CAMERA_RAW_FRAME_BUFFER_ROWS 240
      #define EI_CAMERA_FRAME_BYTE_SIZE 3
      /* Private variables ------------------------------------------------------- */
      static bool debug_nn = false; // Set this to true to see e.g. features generated from the raw signal
      static bool is_initialised = false;
      uint8_t *snapshot_buf; //points to the output of the capture
      static camera_config_t camera_config = {
      .pin_pwdn = PWDN_GPIO_NUM,
      .pin_reset = RESET_GPIO_NUM,
      .pin_xclk = XCLK_GPIO_NUM,
      .pin_sscb_sda = SIOD_GPIO_NUM,
      .pin_sscb_scl = SIOC_GPIO_NUM,
      .pin_d7 = Y9_GPIO_NUM,
      .pin_d6 = Y8_GPIO_NUM,
      .pin_d5 = Y7_GPIO_NUM,
      .pin_d4 = Y6_GPIO_NUM,
      .pin_d3 = Y5_GPIO_NUM,
      .pin_d2 = Y4_GPIO_NUM,
      .pin_d1 = Y3_GPIO_NUM,
      .pin_d0 = Y2_GPIO_NUM,
      .pin_vsync = VSYNC_GPIO_NUM,
      .pin_href = HREF_GPIO_NUM,
      .pin_pclk = PCLK_GPIO_NUM,
      //XCLK 20MHz or 10MHz for OV2640 double FPS (Experimental)
      .xclk_freq_hz = 20000000,
      .ledc_timer = LEDC_TIMER_0,
      .ledc_channel = LEDC_CHANNEL_0,
      .pixel_format = PIXFORMAT_JPEG, //YUV422,GRAYSCALE,RGB565,JPEG
      .frame_size = FRAMESIZE_QVGA,    //QQVGA-UXGA Do not use sizes above QVGA when not JPEG
      .jpeg_quality = 12, //0-63 lower number means higher quality
      .fb_count = 1,       //if more than one, i2s runs in continuous mode. Use only with JPEG
      .fb_location = CAMERA_FB_IN_PSRAM,
      .grab_mode = CAMERA_GRAB_WHEN_EMPTY,
      /* Function definitions ------------------------------------------------------- */
      bool ei_camera_init(void);
      void ei_camera_deinit(void);
      bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) ;
      • @brief Arduino setup function
        void setup()
        // put your setup code here, to run once:
        Serial.begin(115200);
        //comment out the below line to start inference immediately after upload
        while (!Serial);
        Serial.println("Edge Impulse Inferencing Demo");
        if (ei_camera_init() == false) {
        ei_printf("Failed to initialize Camera!\r\n");
        else {
        ei_printf("Camera initialized\r\n");
        ei_printf("\nStarting continious inference in 2 seconds...\n");
        ei_sleep(2000);
      • @brief Get data and run inferencing
      • @param[in] debug Get debug info if true
        void loop()
        // instead of wait_ms, we'll wait on the signal, this allows threads to cancel us...
        if (ei_sleep(5) != EI_IMPULSE_OK) {
        return;
        snapshot_buf = (uint8_t*)malloc(EI_CAMERA_RAW_FRAME_BUFFER_COLS * EI_CAMERA_RAW_FRAME_BUFFER_ROWS * EI_CAMERA_FRAME_BYTE_SIZE);
        // check if allocation was successful
        if(snapshot_buf == nullptr) {
        ei_printf("ERR: Failed to allocate snapshot buffer!\n");
        return;
        ei::signal_t signal;
        signal.total_length = EI_CLASSIFIER_INPUT_WIDTH * EI_CLASSIFIER_INPUT_HEIGHT;
        signal.get_data = &ei_camera_get_data;
        if (ei_camera_capture((size_t)EI_CLASSIFIER_INPUT_WIDTH, (size_t)EI_CLASSIFIER_INPUT_HEIGHT, snapshot_buf) == false) {
        ei_printf("Failed to capture image\r\n");
        free(snapshot_buf);
        return;
        // Run the classifier
        EI_IMPULSE_ERROR err = run_classifier(&signal, &result, debug_nn);
        if (err != EI_IMPULSE_OK) {
        ei_printf("ERR: Failed to run classifier (%d)\n", err);
        return;
        // print the predictions
        ei_printf("Predictions (DSP: %d ms., Classification: %d ms., Anomaly: %d ms.): \n",
        result.timing.dsp, result.timing.classification, result.timing.anomaly);
      #if EI_CLASSIFIER_OBJECT_DETECTION == 1
      ei_printf("Object detection bounding boxes:\r\n");
      for (uint32_t i = 0; i < result.bounding_boxes_count; i++) {
      ei_impulse_result_bounding_box_t bb = result.bounding_boxes[i];
      if (bb.value == 0) {
      continue;
      ei_printf(" %s (%f) [ x: %u, y: %u, width: %u, height: %u ]\r\n",
      bb.label,
      bb.value,
      bb.x,
      bb.y,
      bb.width,
      bb.height);
      // Print the prediction results (classification)
      #else
      ei_printf("Predictions:\r\n");
      for (uint16_t i = 0; i < EI_CLASSIFIER_LABEL_COUNT; i++) {
      ei_printf(" %s: ", ei_classifier_inferencing_categories[i]);
      ei_printf("%.5f\r\n", result.classification[i].value);
      #endif
      // Print anomaly result (if it exists)
      #if EI_CLASSIFIER_HAS_ANOMALY
      ei_printf("Anomaly prediction: %.3f\r\n", result.anomaly);
      #endif
      #if EI_CLASSIFIER_HAS_VISUAL_ANOMALY
      ei_printf("Visual anomalies:\r\n");
      for (uint32_t i = 0; i < result.visual_ad_count; i++) {
      ei_impulse_result_bounding_box_t bb = result.visual_ad_grid_cells[i];
      continue;
      bb.label,
      bb.value,
      bb.x,
      bb.y,
      bb.width,
      bb.height);
      #endif
      free(snapshot_buf);
      • @brief Setup image sensor & start streaming
      • @retval false if initialisation failed
        bool ei_camera_init(void) {
        if (is_initialised) return true;
      pinMode(13, INPUT_PULLUP);
      pinMode(14, INPUT_PULLUP);
      #endif
      //initialize the camera
      esp_err_t err = esp_camera_init(&camera_config);
      if (err != ESP_OK) {
        Serial.printf("Camera init failed with error 0x%x\n", err);
        return false;
      // sensor_t * s = esp_camera_sensor_get();
      // initial sensors are flipped vertically and colors are a bit saturated
      //if (s->id.PID == OV3660_PID) {
      // s->set_vflip(s, 1); // flip it back
      // s->set_brightness(s, 1); // up the brightness just a bit
      // s->set_saturation(s, 0); // lower the saturation
      #if defined(CAMERA_MODEL_M5STACK_WIDE)
      s->set_vflip(s, 1);
      s->set_hmirror(s, 1);
      #elif defined(CAMERA_MODEL_ESP_EYE)
      s->set_vflip(s, 1);
      s->set_awb_gain(s, 1);
      #endif
      is_initialised = true;
      return true;
      • @brief Stop streaming of sensor data
        void ei_camera_deinit(void) {
        //deinitialize the camera
        esp_err_t err = esp_camera_deinit();
        if (err != ESP_OK)
        ei_printf("Camera deinit failed\n");
        return;
        return;
      • @brief Capture, rescale and crop image
      • @param[in] img_width width of output image
      • @param[in] img_height height of output image
      • @param[in] out_buf pointer to store output image, NULL may be used
      •                       if ei_camera_frame_buffer is to be used for capture and resize/cropping.
      • @retval false if not initialised, image captured, rescaled or cropped failed
      bool ei_camera_capture(uint32_t img_width, uint32_t img_height, uint8_t *out_buf) {
      bool do_resize = false;
      if (!is_initialised) {
          ei_printf("ERR: Camera is not initialized\r\n");
          return false;
      camera_fb_t *fb = esp_camera_fb_get();
      if (!fb) {
          ei_printf("Camera capture failed\n");
          return false;
      bool converted = fmt2rgb888(fb->buf, fb->len, PIXFORMAT_JPEG, snapshot_buf);
      esp_camera_fb_return(fb);
      if(!converted){
      ei_printf("Conversion failed\n");
      return false;
      if ((img_width != EI_CAMERA_RAW_FRAME_BUFFER_COLS)
          || (img_height != EI_CAMERA_RAW_FRAME_BUFFER_ROWS)) {
          do_resize = true;
      if (do_resize) {
          ei::image::processing::crop_and_interpolate_rgb888(
          out_buf,
          EI_CAMERA_RAW_FRAME_BUFFER_COLS,
          EI_CAMERA_RAW_FRAME_BUFFER_ROWS,
          out_buf,
          img_width,
          img_height);
      return true;
      static int ei_camera_get_data(size_t offset, size_t length, float *out_ptr)
      // we already have a RGB888 buffer, so recalculate offset into pixel index
      size_t pixel_ix = offset * 3;
      size_t pixels_left = length;
      size_t out_ptr_ix = 0;
      while (pixels_left != 0) {
          // Swap BGR to RGB here
          // due to https://github.com/espressif/esp32-camera/issues/379
          out_ptr[out_ptr_ix] = (snapshot_buf[pixel_ix + 2] << 16) + (snapshot_buf[pixel_ix + 1] << 8) + snapshot_buf[pixel_ix];
          // go to the next pixel
          out_ptr_ix++;
          pixel_ix+=3;
          pixels_left--;
      // and done!
      return 0;
      #if !defined(EI_CLASSIFIER_SENSOR) || EI_CLASSIFIER_SENSOR != EI_CLASSIFIER_SENSOR_CAMERA
      #error "Invalid model for current sensor"
      #endif
      and here is the error
      C:\Users\HP\AppData\Local\Temp.arduinoIDE-unsaved202486-9240-1p71wzh.ggfb\esp32_camera\esp32_camera.ino:382:2: error: #error "Invalid model for current sensor"
      382 | #error "Invalid model for current sensor"
      Compilation error: #error "Invalid model for current sensor"
        salmanfaris @Parves DOMINO last edited by
        @Parves-DOMINO Did you able to solve the issue?
