    What is the best LoRa module to use for long distance network?
    • PumpedMedusa
      PumpedMedusa last edited by
      I'm trying to create an IoT network based on LoRa Wan and ESP32. I have tried using an RA02 module to for transmission of data but the range I'm getting is around 250m. The required range for my project is around 5KM with no line of sight. What is the best way to go about it? Which will be the best LoRa module that I use for this project?
        salmanfaris @PumpedMedusa last edited by
        Hi @PumpedMedusa, The rage is depends on the Antenna and how much TX power you have.
