    How to use Wio Tracker 1110 Dev Board
    Development Boards
    • Vishnuraj2003
      Vishnuraj2003 last edited by
      I'm working with Seeed Studio's Wio Tracker 1110 Dev Board. According to Seeed Studio's documentation, we can use the Wi-Fi antenna inside the Wio Tracker to send data. However, when I used the Sensecraft app, it shows that the board is offline. I have tried connecting it to the Sensecap M2 Gateway but couldn't do it due to a lack of documentation. Please share any advice or resources that could help. Thank you.
        salmanfaris @Vishnuraj2003 last edited by
        Hi @Vishnuraj2003 ,
        As per the documentation, I think we only route the data over the LoRa oR BT. The Wifi is used for sniffing access points for better geo-location and positioning along with GPS.
        And what is the issue you facing when connecting the tracker with gateway? Double check the FREQ on both node and gateway configuration
          salmanfaris @salmanfaris last edited by
          @Vishnuraj2003 Are you able to fix it?
          • @Vishnuraj2003 Are you able to fix it?
          • Hi @Vishnuraj2003 ,
          • I'm working with Seeed Studio's Wio Tracker 1110 Dev Board. According to Seeed Studio's documentation, we can use the Wi-Fi antenna inside the Wio Tracker to send data. However, when I used the Sensecraft app, it shows that the board is offline. I have tried connecting it to the Sensecap M2 Gateway but couldn't do it due to a lack of documentation. Please share any advice or resources that could help. Thank you.
          • @binishmatheww All the best. Let us know if you need any help.
          • @salmanfaris thanks a lot. 👍😁
