    Xiao ESP32C3 - LoRa SPI Issue
    • J
      jibin_lks last edited by
      I been trying to interface Xiao esp32c3 with LoRa via SPI. After uploading the code doesn't get executed by the board but give the message log: "waiting for download". After few attempts by even resigning to other pins as spi instead of default spi pins, found this is occurring specifically when the CS pin is connected to the board. Any help to resolve this?
        salmanfaris @jibin_lks last edited by
        @jibin_lks Can you please share the example code and connection diagram?
