    Can Raspberry Pi 4 handle 24/7 run time
      borncurious last edited by
        salmanfaris @borncurious last edited by
        Hi @borncurious , For the industrial purpose you can go with Raspberry Pi compute modules, Take a look at the latest version CM4 - https://www.raspberrypi.com/products/compute-module-4/ , Which is designed for industrial usage and incorporates a quad-core ARM Cortex-A72 processor, dual video output, and a wide selection of other interfaces. Available in 32 variants, with a range of RAM and eMMC Flash options, and with or without wireless connectivity.
