    Edge Impulse Inference to IoT Dashboard
    edge impulse
    2274
      dipu_varghese last edited by
      Dear Community,
      I am currently working on an Edge Impulse project and have a query regarding the pre-built firmware that can be exported through the platform. Although I am able to read the data through the CLI/serial monitor, I am unsure about how to transfer this inference data/results to an IoT dashboard since the pre-built firmware cannot be edited.
      While I can achieve this through the Arduino library, the accuracy of the inference results is better when using the pre-built firmware.
      Best regards,
      Dipu
        salmanfaris @dipu_varghese last edited by
        Hi @dipu_varghese ๐Ÿ‘‹ ,
        There is two way you can take the data/output information to the cloud.
        1. You need to use the Arduino library for inferencing the model and then push the data in a particular interval or with the triggers. Since the BLE nano sense doesn't have WiFi, you might need to route the network via Bluetooth to the internet-connected gateway, for example, a raspberry pi as DIY or you can transfer the data from Arduino to a wifi controller via serial, for example, transfer the result via UART or I2C to esp8266 or esp32 and then from esp you can push the data to cloud.
        2. The next method is you can use the prebuilt inferencing binary generated by the edge impulse system, as read the serial output with a Wffi or internet-enabled controller, such as raspberry pi, esp32, or esp8266, and after we need to do some processing and cleaning of the data, then push to the cloud.
        These are the method in my mind, please check them and let me know what you think. Happy making ๐Ÿ™Œ.
        D 1 Reply Last reply Reply Quote 1
          dipu_varghese @salmanfaris last edited by
          Hi @salmanfaris
          Thank you for sharing these two methods to take data/output information to the cloud. It's very helpful, and I appreciate your willingness to share your knowledge and expertise.
          Regarding the second method, could you please clarify what kind of processing and cleaning of data needs to be done before pushing it to the cloud? Thank you!
          Best,
          Dipu
            @dipu_varghese The serial data from the prebuilt inferencing binary will be a little big with string size as it comes with all inferencing data points and it's confidence level plus the model information, you might only need the inferencing score or the inferencing data, so you can filter that out and send that to the cloud. Hope you get the idea. Let me know if you need an example.
            D 1 Reply Last reply Reply Quote 0
              Thank you for your response! @salmanfaris ๐Ÿ™‚
              It makes sense that filtering out the specific data points that are needed and sending them to the cloud would be the way to go.
              If it's not too much trouble, could you please provide me with an example of how to filter out and send only the necessary inferencing data to the cloud?
              Thank you again for your help!
              Best,
              Dipu
                @dipu_varghese Sure, I'll try to make an example in one coming day and share.
                D 2 Replies Last reply Reply Quote 0
                  @salmanfaris I really appreciate your help and look forward to seeing the example.
                  Best,
                  Dipu
                    dipu_varghese @dipu_varghese last edited by
                    @salmanfaris Hope you're doing well, did you get sometime to work on this?
                    Best,
                    Dipu
                      @salmanfaris any updates?
                      Best,
                      Dipu
                        salmanfaris @dipu_varghese last edited by salmanfaris
                        Hi @dipu_varghese ,
                        Here is the sample input from the binary edge impulse inference,
                        Predictions (DSP: 16 ms., Classification: 1 ms., Anomaly: 2 ms.):
                        idle: 0.91016
                        snake: 0.08203
                        updown: 0.00391
                        wave: 0.00391
                        anomaly score: -0.067โ€
                        And from here for example we can try to get the updown values only by attaching the device to another controller and read the Serial string directly.
                          // Start serial communication at 9600 baud
                          // Wait until there is data available on the serial port
                          while (!Serial.available()) {
                            // Do nothing
                          // Read the input string from the serial port
                          String inputString = Serial.readStringUntil('\n');
                          // Find the position of the "updown" value in the input string
                          int updownPos = inputString.indexOf("updown:");
                          // If the "updown" value was found in the input string
                          if (updownPos >= 0) {
                            // Extract the "updown" value from the input string
                            String updownString = inputString.substring(updownPos + 8, inputString.indexOf('\n', updownPos));
                        // Convert the "updown" value to a float
                            float updownValue = updownString.toFloat();
                         // Output the "updown" value
                            Serial.println(updownValue);
                        The sketch should then output the "updown" value, which is 0.08203.
                        Hope this will be helpful, let me know if you need more clarification.
                          Hello everyone! Weโ€™re planning on organizing a two-phase event that explores device-to-device communication using ESP-NOW protocol :
                          Weโ€™d love your suggestions on ways to simplify hardware, reducing the cost, secure partnerships and funding, or enhance the interactive elements. Thank you, looking forward to any ideas that can help make the event engaging and successful!
                          Can you share the GPS and LoRa output when itโ€™s working?
