    Blinking LED using Arduino UNO
    • abijith
      abijith last edited by
      It is the simple basic project created using Arduino. LED (Light Emitting Diode) is an electronic device, which emits light when the current passes through its terminals. LED's are used in various applications. It is also used as an ON/OFF indicator in different electronic devices.
      In this project, we will connect the LED to the digital pin on the Arduino board. The LED will work as a simple light that can be turned ON and OFF for a specified duration.
      Video Link :
      https://www.youtube.com/watch?v=QodbHbT8o58&t=104s
        salmanfaris @abijith last edited by
        @abijith Thanks for sharing 🙌.
