    Raspberry pi released new Camera module 3: The classic compact camera for Raspberry Pi with a 12MP sensor and autofocus
        salmanfaris @MakerGram last edited by
        https://www.youtube.com/watch?v=1EIFfln3Kxs&t=1s
