    PCB Design for ESP32 Stand alone module
    pcb esp32
    7
    31
    23860
      @mgfuller333 No not yet, but there seems a quite nice progress in the design. I'm still researching on the antenna interfacing part.
        Sharmila @ZeeZa last edited by
        Hi All, i m also facing the same error. we are developing an iot device based on esp32d0wdq6 controller. we have designed a board. Now the program is not getting uploaded. the connections are
        TTL Converter 3.3v - vcc (ESP32)
        TTL Converter gnd - gnd (ESP32)
        TTL Converter TXD - RXD (ESP32)
        TTL Converter RXD - TXD (ESP32)
        GND - GPIO 0 (ESP32)
        3.3V - EN (ESP32).
        Connecting......................................____An error occurred while uploading the sketch
        _
        this is error message i m getting.
        A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
        FYI, we are using the W25Q40CL flash ic. please help me to sort out this issue.
        Thanks in Advance !
          Sharmila @Sharmila last edited by
          And having one more doubt !
          Bootloader for esp32 will present already or we need to load the bootloader code into the newly brought esp32 chip ?
            @Sharmila If you're programming the board for the first time using Arduino IDE then you need to burn the bootloader into the bare IC. I have a doubt when you said the IC is not getting programmed even though the GPIO0 is low.
            I wanna know is GPIO0 low all the time or did you pull it low momentarily using a button??
              Sharmila @kowshik1729 last edited by
              @kowshik1729 Yes i m programming the board first time using arduion. GPIO 0 is low all the time.
                @Sharmila GPIO0 must not be low all the time. It must be held low only for a moment. Because GPIO0 is a boot strap option for choosing between UART download and normal operation. Please refer to the datasheet and search boot strap. And also can you please post a snap of your newly designed board please?
                S 2 Replies Last reply Reply Quote 1
                  Sharmila @kowshik1729 last edited by Sharmila
                  @kowshik1729 thank you for the hint ! i will check it . schematic picture of my board is given below
                  (freesnippingtool.com_capture_20200721122206.png)
                  saheen_palayi 1 Reply Last reply Reply Quote 1
                    @kowshik1729 sorry, gpio 0 is low only till it is programmed. after that this will disconnected.
                      @Sharmila Reviewed your schematics. Have the following doubts
                      1. Is this a USB receptacle?
                      1. Didn't find any option where you can pull the GPIO0 low and bring it back to normal state. Did you have a jumper connection or button between GPIO0 and GND?
                        1. no.
                        2. we are using jumper for gpio 0th pin. please refer the below image.
