    How to connect TP4056 battery management system with ESP8266
    Development Boards
      Anish_Pillai last edited by
      I wanted to run my NodeMCU board with a li-ion battery. How to use TP4056 safely with NodeMCU and monitor the battery status.
      I am trying to build a pulse oximeter NodeMCU and Max30100 sensor.
        salmanfaris @Anish_Pillai last edited by
        Hi @Anish_Pillai , Are you using the TP4056 standalone module or specific breakout/ready-made boards with NodeMCU?
        You can refer to the circuit below if you use generic readymade modules.
        [Src 📸:electronicspices]
        • @Vishnuraj2003 Are you able to fix it?
        • Hi @Vishnuraj2003 ,
          As per the documentation, I think we only route the data over the LoRa oR BT. The Wifi is used for sniffing access points for better geo-location and positioning along with GPS.
          And what is the issue you facing when connecting the tracker with gateway? Double check the FREQ on both node and gateway configuration
        • I'm working with Seeed Studio's Wio Tracker 1110 Dev Board. According to Seeed Studio's documentation, we can use the Wi-Fi antenna inside the Wio Tracker to send data. However, when I used the Sensecraft app, it shows that the board is offline. I have tried connecting it to the Sensecap M2 Gateway but couldn't do it due to a lack of documentation. Please share any advice or resources that could help. Thank you.
        • @binishmatheww All the best. Let us know if you need any help.
        • @salmanfaris thanks a lot. 👍😁
