    New product: Raspberry Pi Zero 2 W on sale now at $15 / ₹ 1250.
      Raspberry Pi Zero 2 W uses the same Broadcom BCM2710A1 SoC die as the launch version of Raspberry Pi 3, with Arm cores slightly down-clocked to 1GHz, bundled into a single space-saving package alongside 512MB of LPDDR2 SDRAM.
      Here are the highlights:
      • Broadcom BCM2710A1, quad-core 64-bit SoC (Arm Cortex-A53 @ 1GHz)
      • 512MB LPDDR2 SDRAM
      • 2.4GHz IEEE 802.11b/g/n wireless LAN, * Bluetooth 4.2, BLE
      • 1 × USB 2.0 interface with OTG
      • HAT-compatible 40 pin I/O header footprint
      • MicroSD card slot
      • Mini HDMI port
      • Composite video and reset pin solder points
      • CSI-2 camera connector
      • H.264, MPEG-4 decode (1080p30); H.264 encode (1080p30)
      • OpenGL ES 1.1, 2.0 graphics
      src: https://www.raspberrypi.com/news/new-raspberry-pi-zero-2-w-2/
