    Gaming steering wheel setup
    2495
    • V
      Vipin I V last edited by
      Which will be the best setup for gaming steering wheel setup with forcefeedback for PC?with an arduino..
      I've seen people building it vut never found anything perfect?Iam a beginner and i would like to start small for little projects and reach the goal of the setup I've mentioned above...
        salmanfaris @Vipin I V last edited by salmanfaris
        Hi @vipin-i-v . Are you planning to build your own with Arduino?
        V 2 Replies Last reply Reply Quote 1
        • V
          Vipin I V @salmanfaris last edited by
          @salmanfaris yes..istarted building the setup first for a mobile phone and it was a 900° setup,i set it up using different eatio gears as to get the 900°angle...and now I've setup one for pc games as most of the games have mouse steering,so i set it up with that but the position or the centering of the steering wheel is not perfect and the experience is being affected..and by the way your session today with IEDC was great as you shared a possibility for me..😊☺️
          • V
            @salmanfaris And yes I've seen people build it with arduinoes but i never got the idea and I'm a noob at coding and all that..
              @vipin-i-v Yeah, better to follow any of the open projects and build one, then you got a basic idea about how things are working together to achieve the goals, then we can start building our own.
              If you have any favourite "Gaming steering wheel setup" project, please share.
              V 1 Reply Last reply Reply Quote 0
              • V
                @salmanfaris there is readymade stuff to buy,like the logitech g29 and the thrustmaster and also people have built it...I'll try to share a good one below here
                https://youtu.be/Snbkv_mvt8Q
                This one given here is a part 2 video and it has the setup and all that stuff..😊
                  @vipin-i-v Thanks for sharing, project you shared looks nice, since it's have full instructions are you planning to build one?
                  • V
                    @salmanfaris well im planning to start after i get almost all of the supplies but i do not have full list ...I'll be doing it as soon as possible..
                      @vipin-i-v Great, Please let us know the updates, excited to see in action.
                      • V
                        @salmanfaris well i don't know where to start...
