    What kind of interfacing technique you prefer to learn?
    • manthan555
      manthan555 last edited by
      1. ( Arduino + ESP8266 ) + interface anything.
      2. NodeMCU + interface anything.
      3. Arduino Only + interface anything.
      1 Reply Last reply Reply Quote -1
        All of them are using Arduino IDE and it's libraries, so I think it's makes no difference.
