    HID Mouse Emulation using ESP32
      Hi all,
      I am trying to make an application where I would like to emulate a mouse when I plug my device to the computer through a USB cable. I've seen applications where ESP32 pairs with the computer through Bluetooth and emulates the mouse. But I only want to use emulation through the wire.
        ESP32 doesn't have any native USB support right?
          @salmanfaris I guess no, it doesn't have.
            salmanfaris @kowshik1729 last edited by salmanfaris
            @kowshik1729 Then I think it will be difficult, here on this video https://www.youtube.com/watch?v=po3FBdY0GS4 , bitluni's lab used CH559 USB Host controller in order to use the USB HID Services.
            Another possibility is Port V-SUB to ESP32, V-USB is a software-only implementation of a low-speed USB device for Atmel’s AVR microcontrollers
            I found some Github repo's that contain BLE HID
            • https://github.com/asterics/esp32_mouse_keyboard
            • https://github.com/I0x0I/DIY-A-BLE-Keyboard
