    Raspberry pyQT KIOSK
    • Akhil
      Akhil last edited by
      i need to run a QT application on BOOT. and i want to disable all controls like minimize application, close application.
      Anyone have experience in this? please help me.
      THANKS!
        Hi @Akhil I found the following answer in one of the forums. here is the link to the thread.
        The way that I've seen most people do it (have a look on the Raspberry Pi forums), and have done myself with success is using /etc/rc.local.
        All you need to do here is put ./myscript in the rc.local text file. If it's in python, put python myscript.py.
        This literally is "a simple solution, (like dropping my script in some "startup" directory or something similar)"- maybe search on the forums when you're having questions as well, this solution came up on the first 4 results of a google search!
          https://www.dexterindustries.com/howto/run-a-program-on-your-raspberry-pi-at-startup/
          This link has even more extensive ways to do it
