    What's your favorite embedded/prototyping development board?
    Development Boards
    9
    11
    4353
    • Suhailjr
      Suhailjr last edited by
      For beginners as well as intermediate makers i prefer Arduino Micro or Leonardo. It is very easy to use like an Arduino UNO or Nano and has the same features of ATmega328P as well as a must-have feature support built-in USB and can use it as a USB host Device or HID device. I also prefer Arduino Nano boards rather than using Arduino UNO boards because of its size only.
      For simple and minimal projects i love to use ATtiny 16/84/85 microcontrollers(My own boards) or digispark boards. It is cheaper smaller in size and works with ultra-low power mode.
      In the IoT perspective, I prefer ESP8266/ESP32 boards if you want to add wifi/BLE features into your project. The cheapest and the best solution for IoT projects so far. Have large community support and supported by different programming platforms like Arduino IDE, MicroPython, ESP IDF, etc.... Esp32 is a powerful 32-bit microcontroller capable of wrapup any heavy project we think!
      1 Reply Last reply Reply Quote 4
      • @Vishnuraj2003 Are you able to fix it?
      • Hi @Vishnuraj2003 ,
        As per the documentation, I think we only route the data over the LoRa oR BT. The Wifi is used for sniffing access points for better geo-location and positioning along with GPS.
        And what is the issue you facing when connecting the tracker with gateway? Double check the FREQ on both node and gateway configuration
      • I'm working with Seeed Studio's Wio Tracker 1110 Dev Board. According to Seeed Studio's documentation, we can use the Wi-Fi antenna inside the Wio Tracker to send data. However, when I used the Sensecraft app, it shows that the board is offline. I have tried connecting it to the Sensecap M2 Gateway but couldn't do it due to a lack of documentation. Please share any advice or resources that could help. Thank you.
      • @binishmatheww All the best. Let us know if you need any help.
      • @salmanfaris thanks a lot. 👍😁
