    Relay flickering while connecting arduino
    969
      Raman last edited by Raman
      While connecting Arduino with Relay module (Not self made) some times it flickering. May be due to back EMF. How can I avoid this problem.
        One thing you can try is having a diode. It basically allows current in only one direction. And we need more info about how you have connected the circuit and stuff. Please share more info.
        R 2 Replies Last reply Reply Quote 0
          Raman @kowshik1729 last edited by
          @kowshik1729 ok i will sent you bro
            @kowshik1729 it working properly after using a 1N4007 diode
              @Raman Glad to know. All the best for your project.
              R 1 Reply Last reply Reply Quote 2
                @kowshik1729 thank sir its not for our project its for our product bro
                  @Raman woow. Can you share what's the product about with us if it's okay with you??
