    PI have a problem of making Alexa in raspberry pi
    • L
      lakshminarayanan last edited by lakshminarayanan
      Am following this link
      https://www.makeuseof.com/tag/diy-amazon-alexa-raspberry-pi/
      passed the voice test
      But Alexa not working mic and speaker is perfectly working
      Also working audio output
      Mic ( webcam mic)
      It's show some errors command of Alexa stsrt !IMG_20200503_124549088-01.jpeg ![0_1588495499503_IMG-20200503-WA0087.jpeg](Uploading 30%)
        Hi @lakshminarayanan, can you please share the whole error log? from the screenshot we can see that the Alexa installation is not completed! (Make Error).
        also, can you check the r audio setup is correct by running the following.
        sudo /home/pi/Assistants-Pi/scripts/audio-test.sh
        Then Run the Provided Installation Script
        sudo /home/pi/Assistants-Pi/scripts/installer.sh
        L 2 Replies Last reply Reply Quote 0
        • L
          lakshminarayanan @salmanfaris last edited by
          @salmanfaris I have a problem
          Alexa was successfully working at start time
          That's time the audio play in. TV
          HDMI to HDMI (connection)
          After I try to connect my speaker through audio jack ... It's not working
          Again I try to connect TV
          But now I didn't get the clear voice output it's like verry irritating voice (verry delay)
          Pls help me to recover the original voice (sound) of Alexa
          • L
