    Error in burning bootloader to Atmega328P || NEED HELP!!!
      shahidpk last edited by shahidpk
      i brought an ATmega328P MCU with arduino bootloader.And programmed it few times. Worked without any error. But, once i tried to upload a program to it, it won't upload. and i checked the blinking of 13 rd pin won't blinking when reset. So, i thought bootloader is missing and tried to upload bootloader. But get some error. Help please. Error message given below
      Arduino: 1.8.12 (Linux), Board: "Arduino Uno"
      /snap/arduino/7/hardware/tools/avr/bin/avrdude -C/snap/arduino/7/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/ttyACM0 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
      avrdude: Version 6.3-20190619
               Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
               Copyright (c) 2007-2014 Joerg Wunsch
               System wide configuration file is "/snap/arduino/7/hardware/tools/avr/etc/avrdude.conf"
               User configuration file is "/home/shahid/snap/arduino/7/.avrduderc"
               User configuration file does not exist or is not a regular file, skipping
               Using Port                    : /dev/ttyACM0
               Using Programmer              : stk500v1
               Overriding Baud Rate          : 19200
               AVR Part                      : ATmega328P
               Chip Erase delay              : 9000 us
               PAGEL                         : PD7
               BS2                           : PC2
               RESET disposition             : dedicated
               RETRY pulse                   : SCK
               serial program mode           : yes
               parallel program mode         : yes
               Timeout                       : 200
               StabDelay                     : 100
               CmdexeDelay                   : 25
               SyncLoops                     : 32
               ByteDelay                     : 0
               PollIndex                     : 3
               PollValue                     : 0x53
               Memory Detail                 :
                                        Block Poll               Page                       Polled
                 Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                 eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                 flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                 lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                 hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                 efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                 lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                 calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                 signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
               Programmer Type : STK500
               Description     : Atmel STK500 Version 1.x firmware
               Hardware Version: 2
               Firmware Version: 1.18
               Topcard         : Unknown
               Vtarget         : 0.0 V
               Varef           : 0.0 V
               Oscillator      : Off
               SCK period      : 0.1 us
      avrdude: AVR device initialized and ready to accept instructions
      Reading | Error while burning bootloader.
      ################################################## | 100% 0.02s
      avrdude: Device signature = 0x00ff00
      avrdude: Expected signature for ATmega328P is 1E 95 0F
               Double check chip, or use -F to override this check.
      avrdude done.  Thank you.
      when i connect an external supply during bootloader burning the device signature shows as 0x00ff00. and when i connect power to ic from arduino uno 5v pin the device signature is 0x000000😕 😕 😕
      manthan555 2 Replies Last reply Reply Quote 0
      • manthan555
        manthan555 @shahidpk last edited by
        @shahidpk
        In simple way to say your Atmega328p is damaged somehow don't know what happened exactly but you know what's last thing you have done with it...
        If you have external USBASP programmer then use sinaprog software and ARDUINO ISP programming.. use this software and just check wether it indentify your atmega328p or not...if not then surely you damaged it...
        Also first thing to check is disconnect your atmega328p from Arduino and join the RX TX pins by jumper and open serial monitor and type anything and you will echo back what you have typed.. if yes then sure your atmega328p is damaged if no then your serial is crashed but may be your mcu is working but uno can't program by serial pins...
        If you might think that reset is no happened then check reset pin by manually resetting by gnd to reset jumper willingly to do repeated might seem 13 led blinks if not then sure mcu is damaged...
        One another thing or you can say tweak is to renew your mcu by luck of chance doing this...
        Use breadboard..
        Remove your atmega328p from board
        Give a 16Mhz crystal externally
        Connect external reset capacitor and resistor with reset circuit..
        Give VCC and ground...
        Connect reset properly..
        If you have usb external programmer then connect it with ISP pins to atmega328p and now check it whether it identify it or not...
        You can use uno board also with direct RX TX pins + reset pin + external crystal may you try it..
        If all fails go to market and buy new atmega328p or UNO
        • manthan555
          @shahidpk
          Also if may possible that you change the programmer type.. just check it correctly configured or not..
          I forget to say this..
          S 1 Reply Last reply Reply Quote 2
            shahidpk @manthan555 last edited by
            @manthan555 Thanks
