    Need Help on EM-18 reader module and arduino ||Want to read RFID continuously/ periodically
    2167
      salmanfaris @shahidpk last edited by
      @shahidpk I think switching power on/off is not a good option, instead of that, you can try to set Flag for a particular ID and check ID in a time interval and run you task that time interval. Did you check that?
