    The new Raspberry Pi 4
    Raspberry Pi
    raspberrypi
      The Raspberry Pi 4 Model B is finally here, a $35 device that packs a lot of useful technology on a single circuit board you can hold in your hand. It might even be your next budget computer, assuming you can stomach some of the trade-offs enthusiasts have identified in their early testing.
      This tiny tool that powers plenty of people’s clever hacking projects—including dorm room parties—gets a lot of great upgrades for its fourth-generation release. On paper, the specs are impressive: a 1.5 GHz, quad-core, ARM Cortex-A72 processor; up to 4GB of memory (bumping the price to $55); Gigabit Ethernet; wireless-ac; and the ability to push 60 frames per second to a 4K display (or 30 frames per second to two connected 4K displays).
      more : https://www.raspberrypi.org/products/raspberry-pi-4-model-b/
      • Hi @borncurious , For the industrial purpose you can go with Raspberry Pi compute modules, Take a look at the latest version CM4 - https://www.raspberrypi.com/products/compute-module-4/ , Which is designed for industrial usage and incorporates a quad-core ARM Cortex-A72 processor, dual video output, and a wide selection of other interfaces. Available in 32 variants, with a range of RAM and eMMC Flash options, and with or without wireless connectivity.
        Other options are, boards like RockPi and Orange Pi boards which are similar to Raspberry similar model and specs but the price is a bit lower than the raspberry pi. Make sure to check the Interface and driver support that you need to incorporate into your project since these boards are not documented and maintained like the official raspberry pi as far as I know.
        also, you can check Toradex System on Module.
      • B
        Is raspi generally used in commercial product/end product.if not can u guys suggest raspi alternatives for end products.
      • https://www.youtube.com/watch?v=1EIFfln3Kxs&t=1s
        The classic compact camera for Raspberry Pi with a 12MP sensor and autofocus
        Available from $25 with your choice of standard and wide lenses, with or without an infrared filter
        More details: https://www.raspberrypi.com/products/camera-module-3/
        https://youtu.be/XwYRSlqCN3A
        Resource:
        Documentation: https://www.raspberrypi.com/documentation/accessories/camera.html
        Camera Software: https://www.raspberrypi.com/documentation/computers/camera_software.html
      • Hey @rafitc99 ,
        Did your issue resolve? Curious to know 😊
