    help needed in NodeMCU with Blynk integration .
    neo 6m
    1240
      salmanfaris @shankar last edited by
      Hi @shankar ,
      First, try the NodeMCU as standalone and make sure that it's working fine without any problem. then try basic blynk programme with NodeMCU to understand the blynk Virtual Switch and Pin properties.
      also please attach the code, so we can check the syntactical issues.
        shankar @salmanfaris last edited by
        @salmanfaris I uploaded prg "standalone ssl"but nodemcu blue ligth blinking after it .no ligth and it not connecting to my phone
          @shankar Sorry what code is it?? Stand alone?? Please share the snippet...!!
            shankar @kowshik1729 last edited by
            @kowshik1729
            Open ardiuno ide -file -example-blynk-board wifi-stand alone ssl.
            I see a vedio using prg to blinking a led with blynk app
              @shankar Like I said before, can you check a sample programme with NodeMCU.
              try this basic sketch https://www.hackster.io/Salmanfarisvp/webserverblink-using-nodemcu-26e1ed
