    OpenHack: Open River Monitoring System for flood prediction
    Showcase
    open hardware open hack
      So what is OpenHack, it’s an immersive open hackathon where students, professionals, researchers, makers and anyone with an interest in technology gather together to build a single project, disaster management, awareness and alertness platform in two days. I’ve been part of the hackathon as IoT/Hardware mentor from MakeGram community.
      OpenHack is very different from the normal hackathon, in the normal hackathon, it’s all about competition and everyone building a different solution, but here every single one working on the same problem and the same solution collaboratively. πŸ₯°
      I have written a detailed blog on this and you can find here : OpenHack 2019 πŸ‘¨β€πŸ’»: 48hrs Collaborative hackathon Summary
      This thread is to keep a log on Open River Monitoring System
        swalahamani last edited by
        Update - Meeting Summary:
        Agenda: Sensor Selection and Connectivity option
        Time & Date : 10.15 PM to 11.20 PM (23/Sep/2019)
        Attendees: Swalah, Akash, Rafi, Alex and Salman
        We started the discussion from what we have done so far, and we know that we were stuck at sensor and connectivity selection.
        Cellular over LoRa WAN: LoRa WAN is not a good option since we need to set up the complete infrastructure from scratch. Also currently we are only planning to deploy 10 test nodes, it will not be worth setting it up just for that. On the other side, Cellular is already an established network which is feasible to manage 10 devices and can be implemented rapidly. Thus we are planning to go with cellular in the first batch. (Please share your feedback too, it's very important).
        Sensor parameters: After got into a conclusion on the connectivity, we started discussing the sensor parameters to be collected for the analysis and prediction. They are :
        -> Water level (High Priority )
        -> Water Quality
        -> River Flowmeter
        -> Rain Gauge
        Since we only got a few sensors details in past weeks, we decided to list them again based on the parameters and priority. We distributed them based on attendees interest.
        ToDo:
        -> All members are requested to submit sensor details before the next meeting which is scheduled for 7th December 2019 (High Priority)
        -> Documentation: If possible add our Mission and Vision to our GitHub page
        NB: Next team meeting will be on 7th December 2019 from 09.00 PM to 10:00 PM
          @salmanfaris I mainly did this project by following two tutorials in youtube its link is mentioned in my channel.Basically it runs with the help of visual studio code and pycharm.Pycharm is used to detect the hand movement and with the helpm of autopy we move the mouse.By serial port cmmunication we can send the x,ycoordinates in to the arduino and move the servo
        • @athulkrishnakdlr Nice Project, Could you please share more about the technical aspects? What Dev kit are you using and how do you translate coordinates from OpenCV to the servo? Thanks πŸ™‚πŸ‘.
          This is a gesture controlled laser turret,we can control the movement of laser by hand movement.With the help of OpenCV we move the mouse in computer by hand control
          https://youtu.be/sYS2SVur7II
        • Very much informative!!!!
        • If you are using raspberry pi as one of your main computers and have separate monitor, keyboard and mouse, then you might be tired of copy and pasting terminal commands and codes while doing projects with raspberry pi, because running chromium-browser and reading tutorial will pi slower and using a sperate keyboard and mouse use our workbench space too.
          recently I read a blog Share your keyboard and mouse between computers with Barrier by Gordon Hollingworth which is cool.
          In that blog, he mentioned a software called barrier, it's a software that will allow you to use a single keyboard and mouse to control multiple computers by physically turning a dial on the box to switch the machine you're controlling at any given moment. The barrier does this in software, allowing you to tell it which machine to control by moving your mouse to the edge of the screen, or by using a keypress to switch focus to a different system.
          Follow these to share your computer keyboard and mouse with the raspberry pi
          First, we need setup raspberry pi
          Step 1: Download and Install Raspberry Pi OS on SD Card
          Step 2: Connect raspberry pi to the wi-fi network
          Step 3: Install barrier, for that open your terminal (Ctrl + T) and paste or enter the following
          sudo apt install barrier
          Then click enter.
          Step 4: Setup barrier, Open barrier by typing barrier on the terminal, if you successfully installed the barrier you can see like this.
          Select option Client (Use another computer's mouse and keyboard) and Select Auto config option too, also note the Screen name, which we need for the server.
          That's all next we need to set up the desktop/laptop computer.
          Step 5: Download and Install barrier on desktop or laptop computer (The Server), download link
          Step 6: Set up the barrier by selecting Server and position your monitor on barrier software. 004.png
          To Position, the screen clicks the configure server.
          Here, to drag and drop the monitor icon to the desired position you need on the grid.
          double click the screen and set the screen name, you can obtain the screen name from the raspberry pi barrier client. (See Step 4)
          after setup, it should be like this. Then click OK
          in the following screen, click Apply and Just wait few seconds then try to move the mouse to the corner. Yes, It should work.
