    FFT implementation
      Adhu last edited by
      Hello, I have doubt, I want to get the FFT of signals in arduino. I tried to use arduinofft library but have issues in plotting the frequencies present in my signal. any other methods?
        Hi @Adhu ,
        Can you specify the application ? also what was the issues when using the arduinofft lib?
          Adhu @salmanfaris last edited by
          Hi @salmanfaris,
          I want to nullify the effect of noise in PPG signal acquisition. But before that I tried a example code which is present in the arduinofft library in GitHub, to check whether it is working or not?. I got an FFT plot but I think it is wrong. I don't know how to use that library. I'm beginner, so can you help me out? 🙂
