    Compilation Error for Seeed XIAO nRF52840 Sense in Arduino IDE on macOS
    TinyML
    • Abhay
      Abhay last edited by
      Hi everyone,
      I am encountering an issue when compiling a program for the Seeed XIAO nRF52840 Sense in the Arduino IDE on macOS. Below are the details of the problem:
      System Details:
      • Mac Model: MacBook Air M2
      • macOS Version: Sequoia 15.2
      • Arduino IDE Version: 2.3.4
      • Locale: UTF-8 (already configured)
      Board manager details:
      • Additional board Manager URL: https://files.seeedstudio.com/arduino/package_seeeduino_boards_index.json
      • Board installed:
        1. Seeed nRF52 mbed-enabled Boards: 2.9.2
        2. Seeed nRF52 Boards: 1.1.8
      Steps to Reproduce:
      1. Open Arduino IDE on macOS.
      2. Use the default program:
        // the setup function runs once when you press reset or power the board
          // initialize digital pin LED_BUILTIN as an output.
          pinMode(LED_BUILTIN, OUTPUT);
        // the loop function runs over and over again forever
          digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
          delay(1000);                      // wait for a second
          digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
      3. Select Seeed XIAO nRF52840 Sense as the board.
      4. Click on "Verify" or "Compile."
      Observed Behavior:
      The compilation fails with the following error:
      Traceback (most recent call last):
       File "__main__.py", line 317, in <module>
       File "click/core.py", line 1134, in __call__
       File "click/core.py", line 1040, in main
       File "click/_unicodefun.py", line 100, in _verify_python_env
      RuntimeError: Click will abort further execution because Python was configured to use ASCII as encoding for the environment. Consult https://click.palletsprojects.com/unicode-support/ for mitigation steps.
      This system lists some UTF-8 supporting locales that you can pick from. The following suitable locales were discovered: af_ZA.UTF-8, am_ET.UTF-8, be_BY.UTF-8, bg_BG.UTF-8, ca_ES.UTF-8, cs_CZ.UTF-8, da_DK.UTF-8, de_AT.UTF-8, de_CH.UTF-8, de_DE.UTF-8, el_GR.UTF-8, en_AU.UTF-8, en_CA.UTF-8, en_GB.UTF-8, en_IE.UTF-8, en_NZ.UTF-8, en_US.UTF-8, es_ES.UTF-8, et_EE.UTF-8, eu_ES.UTF-8, fi_FI.UTF-8, fr_BE.UTF-8, fr_CA.UTF-8, fr_CH.UTF-8, fr_FR.UTF-8, he_IL.UTF-8, hr_HR.UTF-8, hu_HU.UTF-8, hy_AM.UTF-8, is_IS.UTF-8, it_CH.UTF-8, it_IT.UTF-8, ja_JP.UTF-8, kk_KZ.UTF-8, ko_KR.UTF-8, lt_LT.UTF-8, nl_BE.UTF-8, nl_NL.UTF-8, no_NO.UTF-8, pl_PL.UTF-8, pt_BR.UTF-8, pt_PT.UTF-8, ro_RO.UTF-8, ru_RU.UTF-8, sk_SK.UTF-8, sl_SI.UTF-8, sr_YU.UTF-8, sv_SE.UTF-8, tr_TR.UTF-8, uk_UA.UTF-8, zh_CN.UTF-8, zh_HK.UTF-8, zh_TW.UTF-8
      [15256] Failed to execute script __main__
      Compilation error: exit status 1
      I'm experiencing this issue only with Mac, I tried the same with windows and it ran successfully. I have uninstalled and reinstalled Arduino ide as well.
        salmanfaris @Abhay last edited by salmanfaris
        @Abhay said in Compilation Error for Seeed XIAO nRF52840 Sense in Arduino IDE on macOS:
        @Abhay, are you getting the error while selecting both boards? You can also try using "Seeed nRF52 Boards: 1.1.8".
        Since it's nRF series can you try to install the - adafruit-nrfutil pip package and see!
        also try to install - Adafruit Feather nRF52 using board manager and check again.
        Abhay 2 Replies Last reply Reply Quote 0
        • Abhay
          Abhay @salmanfaris last edited by
          I was using "Seeed nRF52 Boards: 1.1.8" and the issue was there. Followed the steps and installed the packages and board you mentioned and the issue is still there. I changed the board from Seeed nRF to Adafruit nRF and issue is also showing for Adafruit nRF
            @Abhay Can you try one more method
            Downloaded both boards, “Seeed nRF52 Boards” and “Seeed nRF52 mbed-enabled Boards.”
            Copy the adafruit-nrfutil from
            /Users/<user>/Library/Arduino15/packages/Seeeduino/hardware/mbed/2.9.2/tools/adafruit-nrfutil/macos/adafruit-nrfutil
            to
            /Users/<user>/Library/Arduino15/packages/Seeeduino/hardware/nrf52/1.1.8/tools/adafruit-nrfutil/macos/adafruit-nrfutil
            Then chmod -x the copied file
            Please check and let me know. Src
            • Abhay
              @salmanfaris Thank you Salman, This solution worked for me.
                Oracle Fusion Cloud ERP has become a game-changer for modern enterprises looking to streamline their business processes and improve efficiency. Its cloud-based infrastructure offers scalability, real-time insights, and integration capabilities that traditional ERP systems often lack.
                Some key benefits of Oracle Fusion Cloud ERP include:
                Comprehensive Financial Management: Efficiently manage accounting, budgeting, and reporting.
                Supply Chain Optimization: Enhance visibility and control over procurement, inventory, and logistics.
                Human Capital Management: Streamline HR processes and employee lifecycle management.
                Advanced Analytics: Gain real-time insights to make informed business decisions.
                Despite its advantages, implementing Oracle Fusion Cloud ERP can come with challenges such as data migration, user adoption, and customization requirements. Sharing best practices and lessons learned can help organizations maximize the value of this platform.
                I’m curious to hear from the community:
                Has anyone implemented Oracle Fusion Cloud ERP?
                What were your biggest challenges and successes?
                Any tips for smooth adoption and optimization?
                Let’s discuss and share insights about Oracle Fusion Cloud ERP!
              • @Neha-Kamal Nice one, Can you share the project link also here. Thanks 🙌.
              • Hi makers
                i have choosen project theme.
                project title : Still Heard
                “For the ones who stayed quiet but always cared.”
                Still Heard is an interactive emotional companion built for those who’ve ever felt unheard, unseen, or silenced especially in professional or personal spaces.
                looked for some option.
                need to take the input from the user and we have two options
                direct text from user
                or
                capturing emotion using sensors
                i have read about Grove-GSR sensor
                can we use that one?
                Is there any better options ?
              • Hi @rahuljeyaraj ,
                Welcome to the MakerGram community forum, There are several capable development boards available right now for the application. I'm sharing the one we have at our MakerGram inventory,
                For small models, I recommend using - XIAO ESP32-S3 Sense along with Edge Impulse platform to create the model, Here the processing is managed by the esp32 Core itself. It maybe feel slower if the mode it bit heavy.
                next option for small models is Seeed Grove Vision v2 camera where all the processing will done in the inbuilt "Arm Cortex-M55 & Ethos-U55" and you can get the inference results via the I2C or UART from the board, later you can process with Arduino or any XIAO board itself.
                If the model is moderate in size, better to go with Raspberry Pi and v2 or v3 camera and use the Edge Impulse models.
                Currently, we have these board available.
                Hi everyone,
                I’m planning a vision-based AI project where the AI model should run directly on the embedded board (not in the cloud). Based on the inference results, I want to trigger actions like controlling a light or playing a pre-recorded audio file through a speaker.
                Could you please suggest which board or boards would be suitable for this kind of edge AI application? Also, does MakerGram stock such boards?
                Thanks in advance for your help!
