    Arduino boards manager error while installing the ESP32 boards definitions.
      Hi @kowshik1729 ,
      Arduino IDE need internet connection to download tha packages and the error looks like it can't able do that so make sure that you have internet connection on your computer . Also check that you are using Arduino IDE at the 1.8 level or later .
        Thanks for the reply. I am using a stable internet connection and made sure of it. But the issue is not it, according to the internet researches I found that the license certification of the package site https://dl.espressif.com/dl/package_esp32_dev_index.json was expired as of 23rd Septmeber. So, no one will be able to ping the site until it's certification is renewed. I hope it'll be fixed ASAP.
          @kowshik1729, Thanks for the information and you are correct the TLS certificate on dl.espressif.com expired.
          JSON file only for indexing the Different ESP32 boards, so I just move the JSON to my Github repo for an experimental hack, try it and let me know the status
          https://salmanfarisvp.com/ESP/package_esp32_dev_index.json
            Hi @kowshik1729,
            Espressif renewed the certificate today, so try to the official ESP32 Board definition URL to download Board definition.
            URL: https://dl.espressif.com/dl/package_esp32_dev_index.json
            Happy hacking . 👨‍🔧
            kowshik1729 1 Reply Last reply Reply Quote 1
              kowshik1729 @salmanfaris last edited by
              @salmanfaris thankyou sooo much for the info....!!
