    Application Design for Smart Lighting Systems
    UAV
      anselbevier last edited by
      Solution Architecture
      Module Selection: Miniature surface-mount PIR modules (e.g., HC-SR501) with size <20mm×20mm for integration into embedded lighting (ceiling lights, corridor lamps).
      Linkage Logic: Connect to MCUs (e.g., ESP32) via GPIO for "person detected - full brightness; person present - dimmed; person leaves - 30s delay off" control. Integrate light sensors (e.g., BH1750) for daytime auto-shutdown.
      Energy Savings: Reduces lighting energy consumption by 30%-50% compared to traditional switches, ideal for corridors and bathrooms.
      Typical Scenarios
          Smart Homes: Integrates with Alexa/Mijia systems, allowing APP-adjustable sensing distance and delays.
          Commercial Lighting: Mall corridors use zoned sensing via RS485 bus for collaborative multi-module control.
      III. Optimization of Sensing Solutions for Security Systems
      Enhanced Intrusion Detection Design
          Anti-Interference Technology: Dual-element complementary sensors suppress ambient temperature interference; pulse counting (2 consecutive pulses trigger alarm) reduces false positives.
          Multi-Dimensional Linkage: Combines with microwave radar modules (e.g., HB100) for "infrared + microwave" dual detection, triggering alarms only when both activate to avoid curtain sway or insect interference.
          Concealed Installation: Modules with integrated lens-housing designs (e.g., RE200B) hide within ceilings or decor for covert security.
      Data Transmission and Response
          Wireless Transmission: LoRa modules (e.g., EBYTE E32-433T30D) enable low-power long-range (3km open area) data upload, suitable for villa/factory perimeter security.
          Rapid Response: <0.5s trigger delay, with local buzzer alerts and cloud notifications (via NB-IoT) within <3s.
      IV. Selection and Deployment Considerations
      Environmental Adaptation
          Avoid direct exposure to air vents/heating sources. Install at 2.2-2.8m (indoor) or 3-5m (outdoor) height, tilted 15°-30° to cover human activity zones.
          Outdoor use requires IP65 waterproof modules (e.g., AM312-IP67) with sunshades to minimize solar interference.
      Cost-Reliability Balance
          Consumer scenarios: HC-SR501 (~$2/unit); industrial use: Prioritize stability (e.g., Panasonic EKMC1603111, temp drift <±2%/℃).
          Batch deployment: Reserve 10% redundant modules with self-diagnostic voltage checks for fault
        Typical Scenarios Smart Homes: Integrates with Alexa/Mijia systems, allowing APP-adjustable sensing distance and delays. Commercial Lighting: Mall corridors use zoned sensing via RS485 bus for collaborative multi-module control.
        Enhanced Intrusion Detection Design Anti-Interference Technology: Dual-element complementary sensors suppress ambient temperature interference; pulse counting (2 consecutive pulses trigger alarm) reduces false positives. Multi-Dimensional Linkage: Combines with microwave radar modules (e.g., HB100) for "infrared + microwave" dual detection, triggering alarms only when both activate to avoid curtain sway or insect interference. Concealed Installation: Modules with integrated lens-housing designs (e.g., RE200B) hide within ceilings or decor for covert security. Data Transmission and Response Wireless Transmission: LoRa modules (e.g., EBYTE E32-433T30D) enable low-power long-range (3km open area) data upload, suitable for villa/factory perimeter security. Rapid Response: <0.5s trigger delay, with local buzzer alerts and cloud notifications (via NB-IoT) within <3s.
        Environmental Adaptation Avoid direct exposure to air vents/heating sources. Install at 2.2-2.8m (indoor) or 3-5m (outdoor) height, tilted 15°-30° to cover human activity zones. Outdoor use requires IP65 waterproof modules (e.g., AM312-IP67) with sunshades to minimize solar interference. Cost-Reliability Balance Consumer scenarios: HC-SR501 (~$2/unit); industrial use: Prioritize stability (e.g., Panasonic EKMC1603111, temp drift <±2%/℃). Batch deployment: Reserve 10% redundant modules with self-diagnostic voltage checks for fault
      • Hi @Vishnuraj2003, I see you have A203v2 Carrier Board and it will support M.2 Key M disk 2242 as per the product page.
      • I had a doubt regarding the NVME attatchment on carrier board A203 devoluped by Seeed Studio. It specifies different sizes of NVME SSD in the description and specification. Can you please confirm whether it is 2240 or 2242 on the M.2 M slot of the carrier board?001f1be2-8716-41c9-a5e0-a3ffb379a832-image.png
      • @fabme In this case, you need to upload a code XIAO, To fetch the IMU and print on serial. From there, use Edge Impulse CLI to forward the data from the serial to the Edge Impulse.
      • F
        I'm receiving angle values using MPU6050
