    XIAO ESP32 C3 with Edge impulse
    UAV
    • F
      fabme last edited by
      Since this XIAO ESP32 C3 is not compatible with Egde impulse, I'll have to use data logger for it, can anyone guide me about the procedure to collect the data using data logger and then deploying the model to the board?
      Product link: https://www.seeedstudio.com/Seeed-XIAO-ESP32C3-p-5431.html
        salmanfaris @fabme last edited by
        Hi @fabme , What kind of data are you trying to collect, and can you specify the sensor?
        • F
          I'm receiving angle values using MPU6050
            @fabme In this case, you need to upload a code XIAO, To fetch the IMU and print on serial. From there, use Edge Impulse CLI to forward the data from the serial to the Edge Impulse.
              Solution Architecture
              Module Selection: Miniature surface-mount PIR modules (e.g., HC-SR501) with size <20mm×20mm for integration into embedded lighting (ceiling lights, corridor lamps).
              Linkage Logic: Connect to MCUs (e.g., ESP32) via GPIO for "person detected - full brightness; person present - dimmed; person leaves - 30s delay off" control. Integrate light sensors (e.g., BH1750) for daytime auto-shutdown.
              Energy Savings: Reduces lighting energy consumption by 30%-50% compared to traditional switches, ideal for corridors and bathrooms.
              Typical Scenarios Smart Homes: Integrates with Alexa/Mijia systems, allowing APP-adjustable sensing distance and delays. Commercial Lighting: Mall corridors use zoned sensing via RS485 bus for collaborative multi-module control.
              III. Optimization of Sensing Solutions for Security Systems
              Enhanced Intrusion Detection Design Anti-Interference Technology: Dual-element complementary sensors suppress ambient temperature interference; pulse counting (2 consecutive pulses trigger alarm) reduces false positives. Multi-Dimensional Linkage: Combines with microwave radar modules (e.g., HB100) for "infrared + microwave" dual detection, triggering alarms only when both activate to avoid curtain sway or insect interference. Concealed Installation: Modules with integrated lens-housing designs (e.g., RE200B) hide within ceilings or decor for covert security. Data Transmission and Response Wireless Transmission: LoRa modules (e.g., EBYTE E32-433T30D) enable low-power long-range (3km open area) data upload, suitable for villa/factory perimeter security. Rapid Response: <0.5s trigger delay, with local buzzer alerts and cloud notifications (via NB-IoT) within <3s.
              IV. Selection and Deployment Considerations
              Environmental Adaptation Avoid direct exposure to air vents/heating sources. Install at 2.2-2.8m (indoor) or 3-5m (outdoor) height, tilted 15°-30° to cover human activity zones. Outdoor use requires IP65 waterproof modules (e.g., AM312-IP67) with sunshades to minimize solar interference. Cost-Reliability Balance Consumer scenarios: HC-SR501 (~$2/unit); industrial use: Prioritize stability (e.g., Panasonic EKMC1603111, temp drift <±2%/℃). Batch deployment: Reserve 10% redundant modules with self-diagnostic voltage checks for fault
            • Hi @Vishnuraj2003, I see you have A203v2 Carrier Board and it will support M.2 Key M disk 2242 as per the product page.
            • I had a doubt regarding the NVME attatchment on carrier board A203 devoluped by Seeed Studio. It specifies different sizes of NVME SSD in the description and specification. Can you please confirm whether it is 2240 or 2242 on the M.2 M slot of the carrier board?001f1be2-8716-41c9-a5e0-a3ffb379a832-image.png
            • @fabme In this case, you need to upload a code XIAO, To fetch the IMU and print on serial. From there, use Edge Impulse CLI to forward the data from the serial to the Edge Impulse.
            • F
