    PCB Design for ESP32 Stand alone module
    pcb esp32
    7
    31
    24965
      kowshik1729 last edited by salmanfaris
      Hello all,
      I've been trying to make a PCB design for my ESP32 based application. I do not want to use a WROM-32 chip which is SoC instead I want to use my own ESP32 design. My application is to grab the values of accelerometer and gyroscope values from MPU6050 module using ESP32 controller and transmit these values using BLE. So, essentially my design must contain ESP32 chip, Antenna, MPU6050 IC and capacitors, resistors for this design.
      MPU6050 works on the I2C protocol. I am thinking of using an antenna from Antenova. I am attaching my schematic with this post. Please guide me in making my design.
      Zip file link for ESP32 Schematics
        Hi @kowshik1729,
        Do you need an esp32 minimum config design? or ?
          @salmanfaris Yes, exactly.
            Great, also could you please mention esp32 SOC version, there are many different versions, that could be helpful.
              My application needs to use BLE option. So, I would like to get config for WROOM 32. If you feel it is less effecient please do send me ESP32's version suitable for my application.
                take a look at the ESP32 wroom data sheet page number 19, they provided a minimum circuit
                Resource :
                • https://www.espressif.com/sites/default/files/documentation/esp32-wroom-32_datasheet_en.pdf
                • https://www.espressif.com/sites/default/files/documentation/esp32_hardware_design_guidelines_en.pdf
                  @salmanfaris thanks for the reply but this is not exactly what I am looking for I think this is the system on chip version of ESP 32 Wroom. There is no LNA circuit connection for antenna part. Please let me know if you find the the appropriate connections for the ESP 32 stand alone chip. To be simple, I want the circuit that we find when the metal part of SoC is removed.
                    @kowshik1729 so you need the SoC minimum config, not the Module right?
                    Page No. 18
                      Yes, Exactly. I need PCB layout for something as shown below. The rip opened part.
                        @salmanfaris said in PCB Design for ESP32 Stand alone module:
                        take a look at the ESP32 wroom datasheet page number 19, they provided a minimum circuit
                        If you need the module schematic? the use this.
