    PCB Design for ESP32 Stand alone module
    pcb esp32
    7
    31
    24971
      take a look at the ESP32 wroom data sheet page number 19, they provided a minimum circuit
      Resource :
      • https://www.espressif.com/sites/default/files/documentation/esp32-wroom-32_datasheet_en.pdf
      • https://www.espressif.com/sites/default/files/documentation/esp32_hardware_design_guidelines_en.pdf
        @salmanfaris thanks for the reply but this is not exactly what I am looking for I think this is the system on chip version of ESP 32 Wroom. There is no LNA circuit connection for antenna part. Please let me know if you find the the appropriate connections for the ESP 32 stand alone chip. To be simple, I want the circuit that we find when the metal part of SoC is removed.
          @kowshik1729 so you need the SoC minimum config, not the Module right?
          Page No. 18
            Yes, Exactly. I need PCB layout for something as shown below. The rip opened part.
              @salmanfaris said in PCB Design for ESP32 Stand alone module:
              take a look at the ESP32 wroom datasheet page number 19, they provided a minimum circuit
              If you need the module schematic? the use this.
                @salmanfaris Thank you so much. I am exactly looking for SoC minimum config, not the module. Shall ping the forum in case of any hassle.
                  @kowshik1729 Great.
                    @salmanfaris In the figure 3 : ESP32-WROOM-32 Schematics, should I surely use all the capacitors for VDD pins? Are there any redundant connections like these? I want to reduce these unnecessary connections to keep my board size all low as possible. Please suggest how I can optimize the connections?
                      @salmanfaris I've got a doubt. Is there a way to program ESP32 without having USB adapter on the board? Something like how we do for ATMega328p. If there is a way like that please let me know..!! Thanks in advance..!
                        Hi @kowshik1729,
                        Yes, you can. we can programme the esp32 is different methods, and I suggest to use UART like we are using ESP8266, for that you need an FTDI or UART to Serial converter.
                        also make you that before uploading the programme, you need to switch to programme mode, if you share the exact esp32 model, I'll check the modes .
                        Z 1 Reply Last reply Reply Quote 0
