    Created board layout for Voice Assistant controller
    RSET PCB Designing Workshop
    • hisham
      hisham last edited by hisham
      Created board layout for Voice Assistant controller using NodeMCU.
      Circuit:
      Layout:
        Nice 👍
          @hisham The board looks really nice. I am able to see some words written as "Voice Assistance". Do you want to write that name on the top of PCB as a designator or Name to the PCB?
          If so, you have placed the text on the wrong layer. You need to put the text on Top Silkscreen layer which is Layer21 in Eagle. The existing placemet of text will not be seen on the board instead it will be engraved on the top copper layer.
          All the best...!!
          hisham 1 Reply Last reply Reply Quote 2
          • hisham
            hisham @kowshik1729 last edited by hisham
            @kowshik1729 Thank you for your advise. I will correct it soon.
              @hisham also make sure Design Rules are matching with our manufacture capabilities! In this case, we are planned to use Seeed Studio Fusion PCB Service, so you can check their PCB capabilities and configure your PCB Design Rules.
              • Fusion PCB Specification
                @hisham Ahaaa...!! Looks like you've fixed the error. Great job.
                We'll be glad to have a look once your PCB is fabricated...😉
                • @Ggreeshma-stani Pretty good than the previous design. I am able to see 2 crystals on the board. Can I know why did you use another one?
                  And finally, you can address me as kowshik. No need of sir😉
                  @salmanfaris yes sir i have made the changes and have minimised the board size.
                  @kowshik1729 sir i have made the appropriate corrections.
                  and thank you for notifying me on the errors
                • @hisham Ahaaa...!! Looks like you've fixed the error. Great job.
                • @hisham also make sure Design Rules are matching with our manufacture capabilities! In this case, we are planned to use Seeed Studio Fusion PCB Service, so you can check their PCB capabilities and configure your PCB Design Rules.
