    Help needed for ESP8266, GPS neo6m and Firebase
    3624
      Sara last edited by salmanfaris
      Good day all,
      I'm trying to upload the GPS neo-6m data to the firebase realtime database through the ESP8266 wifi module. but, after I uploaded the code nothing happen to the firebase and I can't find the latitude and longitude in the firebase.
      can you please have a look at my code, please? I didn't receive any error messages when I uploaded the code.
      #include <TinyGPS++.h>
      #include <SoftwareSerial.h>
      #include <ESP8266WiFi.h>
      #include <FirebaseArduino.h>
      #include <ArduinoJson.h>
      #define FIREBASE_HOST
      #define FIREBASE_AUTH
      #define WIFI_SSID
      #define WIFI_PASSWORD
      static const int RXPin =0, TXPin =2;
      static const uint32_t GPSBaud = 9600;
      TinyGPSPlus gps;
      // The serial connection to the GPS device
      SoftwareSerial ss(RXPin, TXPin);
        // connect to wifi.
        WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
        Serial.print("connecting");
        while (WiFi.status() != WL_CONNECTED) {
          Serial.print(".");
          delay(500);
        Serial.println();
        Serial.print("connected: ");
        Serial.println(WiFi.localIP());
        Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
      ss.begin(GPSBaud);
       //Serial.println("a");
       while (ss.available() > 0){
          gps.encode(ss.read());
          if (gps.location.isUpdated()){
            Serial.print("Latitude= ");
            Serial.print(gps.location.lat(), 6);
            Firebase.pushString("/lat", "sd");
            Serial.print(" Longitude= ");
           Serial.println(gps.location.lng(), 6);
           Firebase.pushString("/lng", "sd");
        salmanfaris @Sara last edited by
        @Sara , are you able to see the Latitude and longitude on the Serial Monitor ? and are you getting any error or something?
          Sara @salmanfaris last edited by
          @salmanfaris yes I can see the latitude and longitude on the serial monitor and when I used them on the google map I can see my house. Also, there are no error messages received.
            @Sara try this code.
            #include <WiFi.h> // esp32 library
            #include <IOXhop_FirebaseESP32.h>  // firebase library
            #define FIREBASE_HOST "led-control-4631d.firebaseio.com"// the project name address from firebase id
            #define FIREBASE_AUTH "Your Firebase secret key" // the secret key generated from firebase
            #define WIFI_SSID "Your SSID"  // input your home or public wifi name
            #define WIFI_PASSWORD "Your Passcode"   //password of wifi ssid
            String fireStatus = ""; // led status received from firebase
              delay(1000);
              WiFi.begin(WIFI_SSID, WIFI_PASSWORD); //try to connect with wifi
              Serial.print("Connecting to ");
              Serial.print(WIFI_SSID);
                Serial.print(".");
                delay(500);
              Serial.println();
              Serial.print("Connected to ");
              Serial.println(WIFI_SSID);
              Serial.print("IP Address is : ");
              Serial.println(WiFi.localIP());      //print local IP address
              Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);   // connect to firebase
              Firebase.setString("Your feedname", "your value");     //send initial string of led status
              Sara @kowshik1729 last edited by
              @kowshik1729 I received this error message
              Arduino: 1.8.12 (Windows Store 1.8.33.0) (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), 2, v2 Lower Memory, Serial, None, Only Sketch, 115200"
              sketch_mar22b:3:55: fatal error: IOXhop_FirebaseESP32.h: No such file or directory
              compilation terminated.
              This report would have more information with
              "Show verbose output during compilation"
              option enabled in File -> Preferences.
                @Sara https://github.com/ioxhop/IOXhop_FirebaseESP32 Go to this site. Download the zip file.
                Go to your sketch in Arduino IDE -> include .ZIP library -> browse and select your zip file. This will install your library.
                Then try compiling your code.
                  @kowshik1729 still I'm receiving error messages. I think because the esp is different from the esp that mentioned in the code.
                    Yeah, I knew that. Typically ESP8266 can compile most of the codes of ESP32. That's why I asked to compile it once. I will get back to you with one more option.
                      @Sara https://www.instructables.com/id/Esp8266-Firebase-Connection/
                      Please try the instructions here step by step and try it.
                        @kowshik1729 I already did the same steps previously with no result.
