    Custom board for running ML models
    4902
    • kksjunior
      kksjunior last edited by
      Posting something which I've forgot to mention in the first post.
      The Raspberry Pi Compute Module is also an alternative to Toradex SoMs, though you don't have any configurations to choose. There is only one standard model available in every generation of the module.
      Just like the Toradex SoM, even this guy comes with a DDR2 SODIMM connector.
      More Details here.
      kowshik1729 1 Reply Last reply Reply Quote 2
        kowshik1729 @kksjunior last edited by
        @kksjunior Thanks a lot for a very detailed explanation. I shall surely look into the options you've shown and dig more on this.
        kksjunior 1 Reply Last reply Reply Quote 1
        • kksjunior
          kksjunior @kowshik1729 last edited by kksjunior
          @kowshik1729 Keep digging untill you find the gold. All the best! 😄
            @kksjunior Just a small naughty thought😁 ....Is it possible to upgrade the RAM on those RPi modules? I mean if the modules has pin to pin compatibility then can I consider upgrading them? Or will I be having some limitations from the Broadcom SoC they have on board?
            • kksjunior
              @kowshik1729 Haha, Nothing is impossible... Let's say if you get a pin compatible DRAM IC complying to BroadCom SoCs requirement without any limitations to the firmware running upon it you may be able to upgrade it. Provided that you didn't destroy the board while tinkering with it. 😄 The effort to result ratio will never match.
              That's the reason why we get a wide variety of options from manufacturers like Toradex. All the Toradex SoMs belonging to the same device family are pin compatible. You can always upgrade or downgrade your computational module without disturbing the rest of your design!
                Woow, that's awesome. Toradex SoM's looks like beast. WIll surely look into those...!! Thanks a lot again bro..!
                  salmanfaris @kowshik1729 last edited by salmanfaris
                  @kowshik1729 if you are more into ML take a look at the Jetson nano module, it's come with 4GB and 2GM Ram with 128-core NVIDIA Maxwell GPU and Quad-core ARM A57 CPU
                  more information: https://developer.nvidia.com/embedded/jetson-nano
                    @salmanfaris Oh hey woow...this is what I've been searching for. I have contacted Nvidia forums asking for the design files of this module. But those people gave me the design files of the Carrier board. What a waste of time. This is awesome...!! Can I get the design files of this SOM? Not to replicate but just for my reference, practicing, and understanding.
                      @kowshik1729 Please check this, it might help you,
                      • Jetson Nano Module Datasheet
                      • Jetson Nano Product Design Guide
                      • Jetson Nano Thermal Design Guide
                      • Jetson Nano 3D CAD STEP Model
                      • Jetson Nano Developer Kit 3D CAD STEP Model
                      • Jetson Nano Pinmux Table
                      • Jetson Nano Developer Kit Pinmux Table
                      • Jetson Nano Reference Design Schematics
                      • More resource
                      originally drafted and shared by dusty_nv
                        @salmanfaris Actually the schematics files you've mentioned are the same files which I've got from them. They are carrier board design files.😢
                        kksjunior salmanfaris 2 Replies Last reply Reply Quote 0
